It is currently Fri Jun 27, 2025 10:07 am
[ 4 posts ] |
quackit
 Drain Hole on Gatortail
The screw to drain the water out of the lower unit is not coming out. I have bent two screw drivers already anyone have any ideas???
Tue Feb 16, 2010 10:19 am |
craig
Joined: Tue Jan 13, 2009 7:53 pm Posts: 7515 Location: Chauvin
 Re: Drain Hole on Gatortail
Impact screwdriver. Or start it up and put it in gear for a minute.
_________________ 1750 GatorTail Extreme/Stage 3 37 GTR HD Procrastination is a lot like masturbation. Sure it sounds great at the time but, in the end your only f--k--g yourself.
Tue Feb 16, 2010 10:31 am |
MaXXis85
Make sure you got the right phillips head size. THe drill method with a clutch/impact devide will get it out or you need to put a screwdriver in and smack it with a hammer and push tight while unscrewing the plug. Really its not that hard to get it out.. Takes some "thinking" and "doing".
Wed Feb 17, 2010 8:26 am |
WestEndAngler
MMT Moderator
if your talking about the one that faces forward toward the bow of the boat on the bottom of the belt housing... I finally removed that one and put a flat head once I screwed that one up I put in a hex bolt and have never had a problem since.
Wed Feb 17, 2010 9:20 am |
[ 4 posts ] |
Users browsing this forum: No registered users and 134 guests |
