It is currently Fri Jun 27, 2025 2:35 am
Reply to topic  [ 4 posts ]
 Drain Hole on Gatortail
Post Drain Hole on Gatortail
The screw to drain the water out of the lower unit is not coming out. I have bent two screw drivers already anyone have any ideas???
Tue Feb 16, 2010 10:19 am
Post Re: Drain Hole on Gatortail
Impact screwdriver.
Or start it up and put it in gear for a minute. :D
Tue Feb 16, 2010 10:31 am
Make sure you got the right phillips head size. THe drill method with a clutch/impact devide will get it out or you need to put a screwdriver in and smack it with a hammer and push tight while unscrewing the plug. Really its not that hard to get it out.. Takes some "thinking" and "doing".
Wed Feb 17, 2010 8:26 am
MMT Moderator
if your talking about the one that faces forward toward the bow of the boat on the bottom of the belt housing... I finally removed that one and put a flat head once I screwed that one up I put in a hex bolt and have never had a problem since.
GTB 1860 w/ 2019 GTR40XD-HO
Wed Feb 17, 2010 9:20 am
Users browsing this forum: Google [Bot] and 53 guests
