Drain Hole on Gatortail http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=7859 |
Author: | quackit [ Tue Feb 16, 2010 10:19 am ] |
Post subject: | Drain Hole on Gatortail |
The screw to drain the water out of the lower unit is not coming out. I have bent two screw drivers already anyone have any ideas??? |
Author: | craig [ Tue Feb 16, 2010 10:31 am ] |
Post subject: | Re: Drain Hole on Gatortail |
Impact screwdriver. Or start it up and put it in gear for a minute. ![]() |
Author: | MaXXis85 [ Wed Feb 17, 2010 8:26 am ] |
Make sure you got the right phillips head size. THe drill method with a clutch/impact devide will get it out or you need to put a screwdriver in and smack it with a hammer and push tight while unscrewing the plug. Really its not that hard to get it out.. Takes some "thinking" and "doing". |
Author: | WestEndAngler [ Wed Feb 17, 2010 9:20 am ] |
if your talking about the one that faces forward toward the bow of the boat on the bottom of the belt housing... I finally removed that one and put a flat head once I screwed that one up I put in a hex bolt and have never had a problem since. |
