It is currently Thu Jun 26, 2025 10:01 pm
[ 8 posts ] |
Still having a little Trouble
fowl habbit
Joined: Sat Jan 16, 2010 1:52 pm Posts: 1130 Location: THE ONE AND ONLY BUFFALO COUNTY
I have adjusted my valves put new plugs in Im runninglike a 167 main jet I put the needle jet to make it richer but according to the plugs and how the engine sounds Im still running lean. The problem is it sounds like I still have a popping noise coming out the stock exhaust now at wfo not loud but you can here it. I checked over all the exhaust and intake for leaks cant find any air leaks not sure why im still hearing the pop noise and why its still a little lean. Yesterday Im was getting about 4200rpms just me in the 1652 so the motor runs and idles ok just not sure what else to try and adjust. Thanks for any info
Fri Feb 19, 2010 5:20 pm |
bjg
Joined: Thu Jan 15, 2009 7:34 pm Posts: 882 Location: Ahead of you, with a rubber band turning my prop!!
 Re: Still having a little Trouble
Try to preasure up the cylinders with the rockers off and check for valves leaking. Im not talking about compression test im talkin leakdown. Its kind of hard to troublshoot this with out hearing or seeing the engine in person. Ive seen heads crack between the valves and that could be the cause of this.
_________________ BUCK OFAMA
Fri Feb 19, 2010 9:53 pm |
Wilson
Joined: Thu Jan 15, 2009 6:35 pm Posts: 935 Location: South LA
Didn't JD run lean from his rubber Mikuni adapter or primer bulb.....or something like that?
Sat Feb 20, 2010 2:54 am |
JpEater
Joined: Tue Sep 22, 2009 8:02 pm Posts: 245 Location: Augusta, Ga.
How did you check around your intake for leaks? I would spray some brake cleaner around the intake and carb while its running and see if it changes your RPM's. If it does you have a leak.
_________________ Aucoin 18'x48'' Bateau, 30hp GD Longtail.
Sat Feb 20, 2010 8:15 am |
fowl habbit
Sat Feb 20, 2010 10:52 am |
stumpgrinder
wouldn't hurt to pull da nut off da flywheel and look at ur timing key to make sure it ain't sheered.... it's happened before.
_________________ I'm your Huckleberry......... http://www.youtube.com/watch?v=XqVe3xG-wos
I am proud to be an American, I am glad that I am free... but right now I wish I was a dog, and Obama was a tree.
Sat Feb 20, 2010 5:13 pm |
bjg
Sun Feb 21, 2010 1:07 am |
fowl habbit
Sun Feb 21, 2010 9:37 am |
[ 8 posts ] |
Users browsing this forum: No registered users and 122 guests |
