It is currently Fri Jun 27, 2025 1:08 am
Reply to topic  [ 8 posts ]
 go-devil longtail question
Post go-devil longtail question
I picked up an older 10hp longtail the other day four 400 dollars and it appears in good shape. It hadnt been cranked in two years and with fresh gas it fired right up. I noticed the motor had been swapped out at some point and that the shaft key on the motor had a little movement in it. I was wondering if anyone had ever welded the key to the crankshaft and how did it work out. Thanks.
Wed Mar 03, 2010 6:41 pm
Post Re: go-devil longtail question
It'll work out fine until you shear it. Then have fun trying to change it.
Wed Mar 03, 2010 6:43 pm
Good thought maybe i will leave it like it is and just carry a few extra keys with me. Thanks
Wed Mar 03, 2010 7:05 pm
Wed Mar 03, 2010 7:42 pm
Just make the right key for it. I mean if ya need an offset key or something, thats nothin a file and a lil elbow grease wont fix. Is the keyway on the motor a different size than the one in the u joint?
You cant just drill and tap a set screw to hold it in place?
18x58 w/healthy GTR 35
"A good friend will bail you out of jail but a true friend will be sitting by you saying damn that was fun"
Wed Mar 03, 2010 8:50 pm
Wed Mar 03, 2010 8:51 pm
X3 on a set screw. I did that to mine and it never budged in 3 years I ran it like that.
1754 PD w/ 36 PD HTT & FPR
Wed Mar 03, 2010 10:48 pm
Users browsing this forum: No registered users and 84 guests
