It is currently Sat Jun 28, 2025 6:35 pm
Reply to topic  [ 7 posts ]
 Gaskets
Post Gaskets
Is their anywhere else I can get new gaskets for my 35 besides through Mud Buddy. I need 2 upper head Gaskets 2 intake gaskets 2 intake cover gaskets. Im getting my heads back from the shop in town tuesday or wednesday so I would like to get them ASAP
Fri Mar 12, 2010 4:24 pm
Post Re: Gaskets
Jacks small engines. not sure on the part #'s. Someone on here might have em.
You'll need the engine model # off the side your block by the oil filter. it should be 6 digits and start with 613... and the type (example 0110-E1)
http://www.jackssmallengines.com/help.cfm
Fri Mar 12, 2010 4:33 pm
Post Re: Gaskets
Ok Ill try that thanks
Fri Mar 12, 2010 4:51 pm
Post Re: Gaskets
only order 1 valve gasket set,it comes with 2 of everything. I made the mistake and ordered 2 sets for Benelliman,so we now have 4 of everything. The set only cost $31.68 a peice from Jacks.Your model number should be 613477-0121-e1. Your valve gasket set part number is 841123 .Hope this helps.
Don't mistake my kindness for weakness, my ability to look over things as ignorance - but make no mistake, when I've had enough, I'm Coming After you. Watch Your Back....lol
Fri Mar 12, 2010 9:56 pm
Post Re: Gaskets
Any small engine shop that works on Briggs motors should be able to get the m next day for you.
1648 PD
32pd
Sat Mar 13, 2010 12:18 am
Post Re: Gaskets
Get a entire gasket kit from briggs. It even has valve seals in it.
BUCK OFAMA
Sat Mar 13, 2010 12:26 am
Post Re: Gaskets
This site is a good source of ref. #'s to part #'s
http://bsintek.basco.com/BriggsDocument ... rvFVJ1DajI
Gecker carries the nicer Flatout gaskets.
http://www.mudboatmotor.com/html/flatout_gaskets.html
Sat Mar 13, 2010 7:04 am
Users browsing this forum: No registered users and 102 guests
