Mud Buddy 6000 hd + iron mtn heads
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=8453
Page 1 of 2
Author:  fish_hook128 [ Tue Mar 16, 2010 10:43 am ]
Post subject:  Mud Buddy 6000 hd + iron mtn heads
i have a 2008 MB 6000 W/ iron mtn heads, only has 31 hrs on it. runs like $h!t. i can only run about 1/4 throttle before it dies out, i did a suposed upgrade with the irn mtn heads from pro flos at about 25 hrs. it was only running about 22 mph on a 1754 GT with the PF heads so i was talked in to the irn mtn heads for better performance. runs Even worse now, cant even get 10 mph out of it. its been to the shop many times and still has not been fixed, heads constently get stuck and every time there is any pressure(water) on the prop it bogs out and dies. constantly back fires and sounds like $h!t too. i use premium gas and have checked the tank for falt and bad gas, idle's at 1150 rpm and dies out at 2500-3500 rps. any one got any tips/idea's that could help out. feels like i got a lemon. im tired of dumping $ into it and its not being fixed.
Author:  grrifles [ Tue Mar 16, 2010 12:19 pm ]
Post subject:  Re: Mud Buddy 6000 hd + iron mtn heads
Check the rev limiter
Author:  fish_hook128 [ Tue Mar 16, 2010 1:07 pm ]
i just installed a brand new one, so i dont think that its the problem. but the new one makes a ticking sound, is that normal?
Author:  coondik [ Tue Mar 16, 2010 1:18 pm ]
possible causes:
bad cam or cam timing misaligned
sheared or broken timing key
incorrect timing key
bad coil / plug wire
bent push rod(s)
incorrect valve lash settings
rev box wired wrong or not grounded properly
leaking intake / gaskets or carb boot
carbs not in sync
Author:  JIMMY W [ Tue Mar 16, 2010 1:57 pm ]
Bring it to coondik!
Author:  indybill [ Tue Mar 16, 2010 2:06 pm ]
HOOK where do you live???
Author:  bjg [ Tue Mar 16, 2010 6:06 pm ]
Author:  craig [ Tue Mar 16, 2010 6:10 pm ]
Author:  fish_hook128 [ Tue Mar 16, 2010 8:55 pm ]
100 miles north of houston, madisonville tx
Author:  fish_hook128 [ Tue Mar 16, 2010 8:59 pm ]
hey coondik, whats the best place to get this thing looked at, and what would it cost me to fix it, and give me you opnion on this setup.
Author:  deadbird8 [ Tue Mar 16, 2010 9:14 pm ]
You bought that motor from H&W and they sent you to the coast to get it worked on last year when it was running like crap? Sounds like you never get that fixed and then added other heads on it.
The IM heads are nice and produce a lot of power. See the list that coondik posted but you don't have timing keys in yours.
You may try the MB forum for more specific help.
Author:  fish_hook128 [ Tue Mar 16, 2010 9:28 pm ]
the guy from the coast "fixed/replaced" the bent push rod that he said was causing me the problems and added the IM heads at the same time, he dry tested at his shop but when i put it in the water this $h!t happened, i contacted MB and talked to their guru and he talked to a local mechanic and walked hime through a complete rebuild, replaced a Cracked piston rod, oil pump, rev limiter, rings ect... still not worth a damn.
Author:  drake1 [ Wed Mar 17, 2010 5:48 am ]
Your only a 100 miles from EVT. Bring it by and we will see if we can help you out.
Author:  fish_hook128 [ Wed Mar 17, 2010 6:45 am ]
Author:  grrifles [ Wed Mar 17, 2010 6:58 am ]
I have had rev limeters go out in less then an hour. Cut or unplug the green wire and she how it does.
Chris
Author:  craig [ Wed Mar 17, 2010 8:44 am ]
Author:  T-mac [ Wed Mar 17, 2010 9:12 am ]
That's my suggestion too....take it to EVT in Crosby...your best/closest bet-
BTW...who was the person that said you needed Iron Mountain heads to fix your problem?? First thing I'd do is go and take the hundreds of $$$ they ripped you on out of their azz. You got rooked~
Author:  dpd [ Wed Mar 17, 2010 10:19 am ]
Author:  indybill [ Wed Mar 17, 2010 10:30 am ]
Hook,
Did coastal backwater tell you that you needed iron mountain heads or did they suggest that you
add those because they were going into the stock heads anyway? Why did you use them when you bought the motor somewhere else? Agree that Silk at EVT would be a good place to at least call. I have had very good dealings with him. This all seems confusing to me.
Author:  T-mac [ Wed Mar 17, 2010 12:41 pm ]
He said he already had proflow heads and someone suggested he needed Iron Mountains for better performance.
HOw were you talked into it?? and who did??
Author:  fish_hook128 [ Wed Mar 17, 2010 5:07 pm ]
reason: no labor charge and parts at cost. b/c id been back twice before they figured out that the rod was bent.
Author:  deadbird8 [ Thu Mar 18, 2010 4:39 am ]
Author:  fish_hook128 [ Thu Mar 18, 2010 10:40 am ]
i agree. now that i think about i kinda feel like a guinea pig.
Author:  all8up [ Fri Mar 19, 2010 6:56 pm ]
Author:  fish_hook128 [ Thu Mar 25, 2010 7:24 pm ]
Author:  chops3131 [ Thu Mar 25, 2010 7:34 pm ]
Author:  chops3131 [ Fri Mar 26, 2010 2:54 pm ]
We are a cretified mudbuddy performance center if you need any help feel free to call us and visit the site
Author:  indybill [ Fri Mar 26, 2010 3:55 pm ]
Welcome aboard. Sorry for the Jack.
Author:  caddobrook [ Sat Mar 27, 2010 12:41 am ]
Author:  WES [ Sat Mar 27, 2010 1:13 am ]
it sounds simple but if theres a rev liniter on there i bet thats it (like some have said), take it off they get wet and turn to junk.
Author:  fish_hook128 [ Sat May 22, 2010 5:20 pm ]
got my ride back from Extreme v twins today.... its fixed better than when it came from the factory. Robert and mike know there stuff. if you having problems or need help call them.
Author:  brlcla [ Sat May 22, 2010 5:44 pm ]
another satisfied EVT customer
Author:  marshmaster [ Sat May 22, 2010 7:46 pm ]
what was the culprit??? Somthing simple?? Good to here you got it back up and going
Author:  fish_hook128 [ Sat May 22, 2010 8:01 pm ]
there was all kinds of crazyness going....
in short a MB 6000 is not a easy set up to maintain....
now we have a EVT custom exaust with a larger single carb with iron mtn heads on a MB 6000 pushing a GT 17x54 huntdeck
we ran to day 31 mph at 4300 rpm
im happy
Author:  fish_hook128 [ Sat May 22, 2010 8:02 pm ]
ill let EVT explain all the problems
Author:  marshmaster [ Sat May 22, 2010 8:07 pm ]
Kind of exaust did you have before you put the evt exaust on?
Author:  fish_hook128 [ Sat May 22, 2010 8:13 pm ]
MB duel stainless
Author:  marshmaster [ Sat May 22, 2010 8:19 pm ]
Sent you a pm about your pipes
Author:  indybill [ Sat May 22, 2010 9:46 pm ]
Hook,
Good for you. 31 mph is great. Glad you are back up. :D
Author:  fish_hook128 [ Sat May 22, 2010 9:49 pm ]
thanks man me to its been a solid year since its ran right
JR
Page 1 of 2 All times are UTC - 6 hours
