It is currently Sun Feb 01, 2026 9:50 am
Reply to topic  [ 20 posts ]
 Govenor Springs
Post Govenor Springs
Anyone know where I can find aftermarket governor springs for my 36pd? I remember seeing someone with different sizes.
Thanks
Sat Feb 07, 2009 6:23 pm
Post Re: Govenor Springs
I'm running the 23 Briggs spring (black color code) adjusted to 4400 out of water. No issues as of yet.
Sat Feb 07, 2009 9:19 pm
Cool....i could try that. Where can i get one and do you know the part number?
Sat Feb 07, 2009 9:30 pm
I got mine at the local lawn mower shop, just told him what I needed.
Sat Feb 07, 2009 9:33 pm
WTF?... How much weed were you smokin when you thought "Pappy Gander" was anacceptable or somewhat cool screen name.. GAWD! :mrgreen:
"I just want silence. Jesus, it doesn't mean I don't like you. It just means right now, I like silence more."
Wed Feb 11, 2009 9:08 pm
Thu Feb 12, 2009 10:10 am
Foo.. you just got "Railed"... :lol:
Seriously.. I'm sorry if I offended you.. Honest.. Your screen name rocks.. Honest.. I can only hope to aspire to you coolness.. Honest.. :mrgreen:
Thu Feb 12, 2009 11:29 pm
Get a room already :mrgreen:
Josh
"Grace calls us to change and then gives us the power to pull it off!"
Max Lucado
Fri Feb 13, 2009 10:15 am
There are several springs you can get from Briggs but the Purple one is rated for about 4000RPM. The Red and Green ones are rated for lower RPM so don't bother with them. If you want to run higher RPM then you can go with some others. Going higher RPM you can use more travel (longer spring) so it doesn't pull the idle up when you crank down on the govenor adjustment. There is a Gold spring whose length is between the purple one and the large Olive one in the picture. My 35 came with a Purple one but I have a Gold one from another 35- go figure. The long olive one in the picture is what MB uses for their 45, I run one of these at 4500RPM. You can probably get one of the MB 45 springs from the Boat Dr 504-737-1203- he does alot of carb kits on the MBs and may have some just laying around. Hope that helps.
Sat Feb 14, 2009 9:31 am
Some parts numbers for these springs would sure help. All I seem to be able to get from my dealer is the standard old silver spring for my 23.
... or a location where to find them ;)
"They call us civilized, cause we're easy to sneak up on!"
Fri Feb 20, 2009 9:23 am
I talked to Hank at the Boat Dr. and he gave me a lot of good advice. Turns out the 45 MB governer spring may be the same as the 36 PD. I'm waiting on one that I got online from the Briggs Engine Outlet. KP at PD gave me part #842614 for the stock spring that looks like the biggest silver one in Deadbirds picture.
Josh
Max Lucado
Fri Feb 20, 2009 10:49 am
Well, now I'm not sure but the spring that just arrived is painted half red and looks like the red spring in Deadbirds pic. The one I had on the motor and I thought was arriving looks like the no color far right spring. Dunno :|
Josh
Max Lucado
Fri Feb 20, 2009 1:19 pm
Sat Feb 21, 2009 5:15 am
Thanks DB8! Ordered a purple spring form my dealer by that part#, which he DID show in his book.
Briggs & Stratton was LOTS of help :? After 45 minutes on the phone and talking to 4 different "Techs" yesterday, what I finally got was "We don't color code our springs"
Shhhheeeeetttt!!!!!
I'll let ya'll know how it works next week.
Anybody want to come up to NC and help a transplanted coonass take the prop off of my longtail??
Sat Feb 21, 2009 6:53 am
Here is a pic with the Gold spring i mentioned for comparison. Briggs parts and descriptions are pretty frustrating- worst is tryin to get different sized jets for the stock carb!
Sat Feb 21, 2009 7:24 am
The blackmarked 23 van spring I am running is similar to the shorter colored springs that deadbird8 posted, it has more tension than the longer 35/36/45 spring which is what came stock on my motor. With the increased tension and shorter length it helped lessen the pull down effect of the governor when bogging the motor down and during acceleration on my 36.
Sun Feb 22, 2009 6:12 am
I wound up using the stock and a purple spring twisted together on my 23 GDLT. I am turning 4150 RPM out of the water, up from the 3600 I had before. Idle is around 1000 RPM. Can't put it overboard till Sunday to get an in-the-water reading.
Is 4150 RPM too much for a 23 Vanguard?
Fri Feb 27, 2009 4:46 pm
I finally got the stainless steel colored spring that MB used for there 45's. It's the same one that was used to mod my 36. When the weather gets better I'll giver a try.
Josh
Max Lucado
Fri Feb 27, 2009 5:21 pm
Just your basic cracka ass cracka
1840 gator tail with 35GTR
15xx Bateau with 15 honda
Sat Feb 28, 2009 11:31 am
Finally got that 4500 RPM spring on and what a difference it made. 4500-4600 WOT with prop turning out of the water and 1000-1100 at idle. Hopefully it'll work out when I get in the water.
Josh
Max Lucado
Sat Feb 28, 2009 9:41 pm
