It is currently Fri Jun 27, 2025 12:27 pm
Reply to topic  [ 15 posts ]
 PTO Switch
Post PTO Switch
Guys,
I brought my boat into prodrive this past week and got some work done on the the engine. They got the issues fixed for me now I got my boat back on friday and took a ride to the camp, and my PTO switch fried on me. So I called Bart the mechanic on saturday and drove to franklin and bought 2 new switches and went back to the camp. Sunday morning while checking the trout line fried the first of the two new switches. I pulled the cover changed the switch cranked up and ran 2 milli seconds and burnt that one too. I checked all the wires none of them seem to be shorting out any where. And it was working completly fine up until this weekend. I had to electric tape a AA battery to the momentary button to make it home all the way from the bay. Anyone have any ideas or have had this happen???
1754 GT EXTREME 37EFI
Sun Apr 04, 2010 9:30 pm
Post Re: PTO Switch
I would call KP at PD and discuss with him.
He will get you sorted out.
Not sure what part of the switch you replaced, but there is more than just the switch that needs to be replaced when there is a problem..
Had the same issue (but only once) and he sent us what we needed and got it fixed right up.....
Mon Apr 05, 2010 8:42 am
Post Re: PTO Switch
Mon Apr 05, 2010 9:22 am
Post Re: PTO Switch
Mon Apr 05, 2010 9:52 am
Post Re: PTO Switch
Mon Apr 05, 2010 10:03 am
Post Re: PTO Switch
I didn't studder Brian at prodrive fixed my engine last week and I called bart to get the switches instead of driving all the way to prodrive. Answer the question J, don't be so analytical next time!!
Mon Apr 05, 2010 12:02 pm
Post Re: PTO Switch
LA Outlaw, What kind of work did you have done to the engine at ProDrive in L-Ville?
It is possible that some wires running from the PTO switch got pinched, chafed, kinked or whatever, when they did the work and now you are having a short in the switch? Perhaps the clutch is going out?
Mon Apr 05, 2010 12:16 pm
Post Re: PTO Switch
Damn, that sucks. My guess would be call PD back and see whats up.
ETD88 09/28/09-05/14/2010...
Mon Apr 05, 2010 12:18 pm
Post Re: PTO Switch
Sorry for being so whatever word you stated.
Mon Apr 05, 2010 2:46 pm
Post Re: PTO Switch
Mon Apr 05, 2010 4:24 pm
Post Re: PTO Switch
Mon Apr 05, 2010 6:05 pm
Post Re: PTO Switch
Kingfish had the same problem down this way, His switch went out in the middle of the second split. He ordered a new one from PD got it the next day ( dem boys don't play!). We installed it and with in 5 minutes it too stopped working ( smelled like burning plastic at the switch but visually it looked fine ). We traced out the clutch wires from the clutch to the control box looking for any tell tale signs of a short but found nothing. We called Peck ran it by him and he said that the clutch's coil might be shorting out internally.
Now here's the kicker, I took the PTO switch off my motor (07) because I thought the new switch looked/felt cheap and we were dead in the water any ways. After installing it we put it in gear it and it stayed running! We let it run in the back yard for 3 hours. throttling it up every now in then. No problems what so ever.
But in less then a week his clutch quit working all together! Bad clutch and cheap switches. IMO ( they don't make em like they use too!)
Mon Apr 05, 2010 6:19 pm
Post Re: PTO Switch
Tue Apr 06, 2010 9:42 am
Post Re: PTO Switch
Well I took a ride down to prodrive and it turns ou the little plug that connects the wire harness to the clutch had a wear spot on one of the connectors and it was shorting the switches they had it fixed in less than 10 mins and I was back in business!!!! Customer service is TOP NOTCH!!!!!! And they bend over backwards trying to help out a customer!!!!!!!!
Tue Apr 06, 2010 1:09 pm
Post Re: PTO Switch
Sorry I didn't see this sooner, I could have helped. As seen below, I had the same thing happen to me as a result of wear at the connector and the first time, dismissed it as a bad switch. Got myself in a bind in some mighty sharp rocks and had to drive back out holding the momentary button. Luckily, I didn't break a finger (or worse) and only ended up with the John Deere PTO switch in a "fashionable" yellow since there was no one in the area that carried the standard one. Glad you got it figured out!!
Custom...Oh Yeah!!!
(At least it matches my key float) :lol:
17x54 Gen 3 EFI
Tue Apr 13, 2010 6:54 am
Users browsing this forum: No registered users and 193 guests
