Carb and Exhaust only
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=8983
Author:  MS [ Sun Apr 11, 2010 11:09 am ]
Post subject:  Carb and Exhaust only
Is it worth doing just the carb and exhaust? Im running at 4300ft of elevation and hoping to jet the mukuni to run a little better at this elevation. So im wondering what kind of gains to expect? Thanks for the help!
Author:  indybill [ Sun Apr 11, 2010 11:20 am ]
Post subject:  Re: Carb and Exhaust only
Most recognizable gains will be in throttle response. Even at altitude with the right jetting you should see a quicker response to the throttle and a more even acceleration throughout the hole shot to get on step. You are improving your air flow. If you checkout the posts by DeadBird8 to see his modification to the stock intake manifold you will see another low-no cost mod that will also help to modify your overall airflow. Kind of a Poor Mans Tuned Intake Manifold. Good Luck.
Author:  chops3131 [ Tue Apr 13, 2010 6:02 pm ]
I have a special going on rite now for that with a prop if you dont need the prop i can take it out
http://www.setxperformance.com/Big-Thre ... 323232.htm
Author:  chops3131 [ Tue Apr 13, 2010 6:53 pm ]
35 Vanguard engine on a dyno.
Here are the results of adding a single carb kit.
These are the Averages
Here is a stock 35 before the carb:
Engine RPM= 3284 / Torque FT LBS = 51.18 / HEAD TEMP = 1309.88 / EXG TEMP = 1213.25 / Obs Tq. = 51.19 / Obs HP = 31.94 / Corr. Tq. = 53.34 / Corr. HP = 33.28
With the single carb :
Engine RPM = 3778 / Torque FT LBS = 52.09 / HEAD TEMP = 1442.15 / EXG TEMP = 1368.35 / Obs Tq. = 52.09 / Obs HP = 37.04 / Corr. Tq. = 54.46 / Corr. HP = 38.72
Peak stock HP was 37.53 HP @ 3775 RPM
Peak with the Single Carb was 43.88 HP @ 4376 RPM
Author:  MS [ Wed Apr 14, 2010 9:24 pm ]
Very interested can you give me a price without the prop? Thanks for the help.
Author:  chops3131 [ Wed Apr 14, 2010 9:30 pm ]
Author:  chops3131 [ Wed Apr 14, 2010 9:44 pm ]
Author:  MS [ Wed Apr 14, 2010 9:54 pm ]
Don't take this wrong, but isn't Mudbuddy selling the carb kit for $695 and the crossover exhuast on sale for $399. So a total of $1094. Are you offering something more with your kit? Free shipping? Just trying to find the best deal.
Author:  chops3131 [ Wed Apr 14, 2010 9:57 pm ]
Author:  chops3131 [ Wed Apr 14, 2010 10:04 pm ]
Its at $480 plus shipping on there
Author:  Rail [ Fri Apr 16, 2010 6:33 am ]
Author:  chops3131 [ Fri Apr 16, 2010 8:46 am ]
Author:  drake1 [ Sun Apr 18, 2010 8:26 pm ]
The head temps ar ewhat's scary. :shock:
Author:  brlcla [ Sun Apr 18, 2010 10:30 pm ]
he just posting this.... http://www.backwaterperformancesystems. ... %20Kit.htm
he also didnt say the engine had 3 deg timing also...
Author:  chops3131 [ Mon Apr 19, 2010 9:10 am ]
Author:  stualaska [ Mon Apr 19, 2010 9:56 am ]
Does the electronic spark advance built into the marine engines coils change these numbers?
