Cm
Joined: Thu Mar 11, 2010 10:24 am Posts: 13 Location: south louisiana
 compression
i have a gtr 35 im running 145 150 in one cylinder and 130 in the other. jus wondering if that is good numbers for a stock motor?
Sun Apr 11, 2010 7:07 pm |
craig
 Re: compression
Yeah....thats about right.
How many hours on the engine?
Sun Apr 11, 2010 7:13 pm |
Cm
 Re: compression
689
Sun Apr 11, 2010 7:19 pm |
craig
 Re: compression
Considering that those are great numbers! LOL
Sun Apr 11, 2010 7:22 pm |
craig
 Re: compression
Have a good valve job done and they (comp. numbers) should come up a little.
Sun Apr 11, 2010 7:24 pm |
quackconsumer
 Re: compression
Sun Apr 11, 2010 7:25 pm |
Tenpoint
Joined: Thu Aug 27, 2009 5:22 pm Posts: 2029 Location: Patterson LA
 Re: compression
Should they be within about 10 pounds of each other like with outboards, or is that not really a big deal?
_________________ 19x48 Rink/Aucoin Bateau w/35 GTR 20x60 Home-made skiff w/200 Merc
Sun Apr 11, 2010 7:29 pm |
Cm
 Re: compression
Jus reset my valves bout 2 months ago. The gauge I used was kinda old it could of been a little off too.
Sun Apr 11, 2010 7:38 pm |
cb5331
 Re: compression
I think its a 10% tolerance not 10lbs, but not sure
Sun Apr 11, 2010 7:39 pm |
craig
 Re: compression
Sun Apr 11, 2010 7:41 pm |
Cm
 Re: compression
Wut should the compression be on a new stock motor? And is the compression that I have now good considering they r more than 10% defferent and I have 689 hours on my motor
Sun Apr 11, 2010 8:09 pm |
craig
 Re: compression
130-150 is pretty much the norm for stock engines.
Sun Apr 11, 2010 8:11 pm |
cb5331
 Re: compression
Sun Apr 11, 2010 9:35 pm |
Cm
 Re: compression
Thanks for da info guys. I figure I'll run the motor stock till it craps out then head work an carb. time.
Mon Apr 12, 2010 5:26 am |
