| oh F*** help !!!!! http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=903 |
| Author: | wcbillcollector [ Mon Mar 02, 2009 12:39 pm ] |
| Post subject: | oh F*** help !!!!! |
Guys, Have any of you'll had a 35 van. just die on you? Full gas tank, kill switch is good and it shuts down like you just turned off the ignition? Someone told me something about a low oil shut off censor? The oil might be a little low but F***. You want to talk about freak'n out took the wife out on a pleasent Sunday run in the local marsh and this s*** happens, not to mention she's 7 MONTHS PREGNATE. Talk about some s*** talk'n all I could think about was hav'n to pack her azz out of there. Gotta get this issue resolved before anymore trips. Any help would be greatly appreciated. |
| Author: | craig [ Mon Mar 02, 2009 12:51 pm ] |
| Post subject: | Re: oh F*** help !!!!! |
It could very well be a little low on oil. Normally, just add a little oil to it and give it a crank. Most Briggs engines come with low oil shutoffs. It is a good idea to carry an extra quart of oil with you in the boat. Keep us posted as to what you find. Good luck. |
| Author: | Hizzoner [ Mon Mar 02, 2009 12:53 pm ] |
Make sure your tank can breathe |
| Author: | Sand Man [ Mon Mar 02, 2009 12:56 pm ] |
Didn't I read something about the 35vans having a wire that the insulation would rub off causing a short to ground and killing the engine???? |
| Author: | BROOKS [ Mon Mar 02, 2009 4:43 pm ] |
Sounds to me like the infamouse ten dolla diode wire harness .... |
| Author: | dylndaw [ Mon Mar 02, 2009 5:36 pm ] |
Did it crank right back up or did it hesitate? |
| Author: | Mud Slinger [ Mon Mar 02, 2009 8:36 pm ] |
might be ethanol fuel issues |
| Author: | wcbillcollector [ Mon Mar 02, 2009 8:57 pm ] |
I had to choke it a little but it would always crank back up. The tank's vent is fine, the oil looked ok when it was level, but Brooks said something about a diode wire harness. The motor is a 35 van Mud buddy. Once again any other input is greatly appreciated. Thanks Guys |
| Author: | craig [ Mon Mar 02, 2009 8:59 pm ] |
You probably should have left out the mud buddy part. |
| Author: | PaulDarensbourg [ Mon Mar 02, 2009 9:13 pm ] |
| Author: | wcbillcollector [ Mon Mar 02, 2009 9:36 pm ] |
yea I was trying to aviod any harrassment because I knew it was coming out sooner or later. |
| Author: | deadbird8 [ Tue Mar 03, 2009 4:37 am ] |
Oil sensor's on the left side (looking at the motor) single wire to it under the crank case breather tube. There's also a fuel shut off solenoid at the carb - two wires go to it. What did you do to get it started again? |
| Author: | BROOKS [ Tue Mar 03, 2009 6:06 am ] |
I didn't relize it started back up ... sorry. So it do git fire in the wire ? I ain't no engine expert. How long have you ran that engine before this mishap ? |
| Author: | wcbillcollector [ Tue Mar 03, 2009 8:05 pm ] |
Think i may have an idea what went wrong. Oil was good, Gas tank vent was good. I had ran this motor acouple of time before with no problems, but i happen to look at the gas and i only had about a 1/4 inch of gas left in the tank (custom gas tank). The wind was blowing its azz off that day and we had some pretty choppy waves rock'n the boat a little. Do you'll think the motor my have sucked some air shut down and then caught prime again and fired right up? |
| Author: | deadbird8 [ Tue Mar 03, 2009 11:17 pm ] |
They kinda need fuel to run.. |
| Author: | Mike W. [ Wed Mar 04, 2009 11:18 am ] |
Damm! I thought that Mud Buddy had trained them things to run without gas! Oh well, there are those who have and those who will. |
| Author: | Crews [ Wed Mar 04, 2009 5:43 pm ] |
| Author: | dylndaw [ Wed Mar 04, 2009 6:12 pm ] |
f***mb help!!!!!! |
| Author: | wcbillcollector [ Wed Mar 04, 2009 10:00 pm ] |
| Author: | wcbillcollector [ Wed Mar 04, 2009 10:01 pm ] |
thanks Crews. |
| Author: | craig [ Thu Mar 05, 2009 6:18 am ] |
I would have definitely left that part out also!! |
| Author: | brentfonty [ Thu Mar 05, 2009 9:27 am ] |
now me no i bee slow buts i no to checks me gas tanks before go out an caught mees snakees |
| Author: | dylndaw [ Thu Mar 05, 2009 9:18 pm ] |
say what??????????????? |
| Author: | dylndaw [ Thu Mar 05, 2009 9:19 pm ] |
