b_coonass
Joined: Thu Mar 26, 2009 2:08 pm Posts: 1229 Location: morgan city, louisiana
 performance cam
I was looking on the SETX performance web site an im thinking about getting a performance cam they have. What other mods do you have to have to be able to run the cam? Can i run it with a stock carb?
_________________ 36hp Pro-Drive with EVT exhaust pushin a 17x42 custom skiff
Wed Apr 14, 2010 1:06 pm |
Rail
 Re: performance cam
Should be able to but cams kinda work hand in hand with heads, intake and exhaust.. All allow you to pump more air.. Doing just one and none of the others is like whipping before you poop.. Don't make much sense..
_________________ "I just want silence. Jesus, it doesn't mean I don't like you. It just means right now, I like silence more."
Fri Apr 16, 2010 6:27 am |
b_coonass
 Re: performance cam
Fri Apr 16, 2010 6:29 am |
River
Joined: Wed Jan 14, 2009 8:34 am Posts: 1092 Location: Unaffiliated, SETX group has caused me to renounce my Texas Citizenship
 Re: performance cam
_________________ "Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the outcome of the vote."-Benjamin Franklin
Fri Apr 16, 2010 9:18 am |
coondik
 Re: performance cam
Fri Apr 16, 2010 11:49 am |
earl33
Joined: Wed Sep 16, 2009 3:47 pm Posts: 2261 Location: West Tennessee
 Re: performance cam
_________________ If the Steel aint Flying the Birds aint Dying.... Uncle J 1948 holding a LT Uncle J 1848 w/?
Fri Apr 16, 2010 11:50 am |
Rail
 Re: performance cam
Guess I got a little carried away with myself.. Whip, Wipe, it all works out in the end..
Mon Apr 19, 2010 1:35 pm |
take'emgator
Joined: Mon Oct 19, 2009 6:38 pm Posts: 10201 Location: SETX
 Re: performance cam
Mon Apr 19, 2010 2:40 pm |
bjg
Joined: Thu Jan 15, 2009 7:34 pm Posts: 882 Location: Ahead of you, with a rubber band turning my prop!!
 Re: performance cam
Heads before cam.
_________________ BUCK OFAMA
Mon Apr 19, 2010 5:54 pm |
Crews
Joined: Wed Jan 14, 2009 9:07 pm Posts: 2260 Location: Lafayette
 Re: performance cam
if you don't know how a damned cam works, you probably don't need one in your motor.
_________________ 24x60 Dual Prodrives
Tue Apr 20, 2010 9:05 am |
coondik
 Re: performance cam
Tue Apr 20, 2010 9:38 am |
MaXXis85
 Re: performance cam
Cam is the heart of the motor. It controls, when a valve opens, how high it pushes the valve open, and how long to keep the valve open. This alone without the proper flow will not be a good combination as others stated!
Tue Apr 20, 2010 12:19 pm |
