It is currently Fri Jun 27, 2025 12:28 pm
Reply to topic  [ 7 posts ]
 Fuel question 87 vs 91 octane
Post Fuel question 87 vs 91 octane
I know for sure now that my modded motor won't run on 87 octane because its crapped out twice. I did it once to save a buck and could barely break 2k rpms and sputtering like a SOB. I thought it might have just been only old 87 gas but I guess not cause it did the same thing with fresh 87. I know now I can only run 91 which I normally do but can't toss in 87 in a pinch :? Each time the spark plugs needed to be changed, fresh 91 octane and it fixed her right up.
Is it because of the head compression and modifications? I'm by no means knowledgeable on this subject. Polished and ported heads and some other minor mods is all it has. Anyone? :?:
Josh
"Grace calls us to change and then gives us the power to pull it off!"
Max Lucado
Fri Apr 16, 2010 12:17 pm
Post Re: Fuel question 87 vs 91 octane
What mods do you have? It doesn't sound like octane rating is your problem. That (87 octane)wouldn't cause your engine to not turn up rpm's.
Fri Apr 16, 2010 12:21 pm
Fri Apr 16, 2010 5:21 pm
I can get the RPMS up but the motor will choke out and shoots out black smoke. I don't have a problem running with 91 octane now. The head is milled, ported and polished. Maybe I should ask what mods won't run 87 octane? There could be something else going on but right now, leaving it running 91 octane fixes it so I might just have to leave it at that.
Josh
Max Lucado
Fri Apr 16, 2010 11:00 pm
Higher octane fuel combats predetonation with a higher compression motor.
Mon Apr 19, 2010 9:01 am
Josh
Max Lucado
Mon Apr 19, 2010 2:52 pm
I run 93 in my stock motor. It seems to run a little better and the motor dosent want to diesel when I turn it off like it did with 87.
Tue Apr 20, 2010 6:42 am
Users browsing this forum: No registered users and 194 guests
