is my kill switch posed to be normally open?
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=9402
Author:  Da-Cajun-Angla [ Thu Apr 29, 2010 8:04 am ]
Post subject:  is my kill switch posed to be normally open?
i hooked up a normally open kill sw and its workin bass-akwards...is it posed to be normally open or did i cross wires or sumtin'? i connected da wires tween the wires on da kill switch...wtf did i do wrong. when the button is pressed it turns da motor off. sad thing is i sell elec. supplies 4 a living! :roll: :lol:
Author:  WestEndAngler [ Thu Apr 29, 2010 8:21 am ]
Post subject:  Re: is my kill switch posed to be normally open?
Author:  Da-Cajun-Angla [ Thu Apr 29, 2010 8:45 am ]
Author:  WestEndAngler [ Thu Apr 29, 2010 9:02 am ]
Author:  dog walker [ Thu Apr 29, 2010 9:10 am ]
cajun call coco
Author:  Da-Cajun-Angla [ Thu Apr 29, 2010 9:42 am ]
Author:  duckman [ Thu Apr 29, 2010 1:25 pm ]
It is suppose to be an N/C (meaning it is making contact), when the contact is broken then it will turn the motor off. You cannot hook up the wires backwards, because it is only 2 wires (doesn't have to be hooked up a curtain way). If your motor won’t start with the kill switch (plastic piece) in, then something is wrong. Either the kill switch or the wiring. If you have a meter you can check the kill switch, by putting the meter to read ohms (u) then touch the 2 wire post. If the meter reads something with the kill switch in place, remove the kill switch and put the meter across the 2 wire post, if you don’t get anything than the kill switch is good.
Author:  dylndaw [ Thu Apr 29, 2010 5:19 pm ]
no such thing of a/c on a mud motor .....yet :shock:
Author:  brlcla [ Thu Apr 29, 2010 5:28 pm ]
Author:  Da-Cajun-Angla [ Fri Apr 30, 2010 7:47 am ]
Author:  TinySack [ Mon May 03, 2010 10:25 pm ]
Author:  TinySack [ Mon May 03, 2010 10:28 pm ]
i dont know exactly its just that how our silicone control RECTIFIERS on our rig works after the power is saturated by excitation from our D.C. EMD generators
Author:  TinySack [ Mon May 03, 2010 10:32 pm ]
and the excitation is from the exciter board before its reaches the ac module. but that would be cool for the motors to have a power inverter you could connect to your motor to have 120 vac like a generator. we def have the engine power to put out some serious current.
Author:  TinySack [ Mon May 03, 2010 10:34 pm ]
none of that was like a nerd rage at all more like blabbering on so dont hate on me not being a smart asz. after reading it again i think i ment to say converter i think. ok im done
