It is currently Fri Jun 27, 2025 5:46 pm
Reply to topic  [ 3 posts ]
 auxiliary oil cooler
Post auxiliary oil cooler
i was wondering how much more oil with this thing take i used the part number sir coondik provided but if any help i would aprreciate it thanks
BUNDY BUILT SKIFFLESS
cuz der bad ass like dat....
bunnny rabbit customs.
Fri May 07, 2010 11:29 am
Post Re: auxiliary oil cooler
Not sure how much extra oil you'll need with it, but once you get it installed, you can remove your kill switch lanyard and crank the motor a few times (that way it won't start) and that should move some oil around through the cooler, then check your dip stick and add as needed. At least that's what I do whenever I change the oil in my motor as directed by Go-Devil.
1644 Go-Devil
2008 23 GDSD
Fri May 07, 2010 1:13 pm
I like theese better.
http://www.jegs.com/p/JEGS/JEGS-XHP-Tra ... 1/10002/-1
Fri May 07, 2010 1:30 pm
Users browsing this forum: No registered users and 115 guests
