auxiliary oil cooler http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=9558 |
Author: | bundy [ Fri May 07, 2010 11:29 am ] |
Post subject: | auxiliary oil cooler |
i was wondering how much more oil with this thing take i used the part number sir coondik provided but if any help i would aprreciate it thanks |
Author: | duckbill [ Fri May 07, 2010 1:13 pm ] |
Post subject: | Re: auxiliary oil cooler |
Not sure how much extra oil you'll need with it, but once you get it installed, you can remove your kill switch lanyard and crank the motor a few times (that way it won't start) and that should move some oil around through the cooler, then check your dip stick and add as needed. At least that's what I do whenever I change the oil in my motor as directed by Go-Devil. |
Author: | quackconsumer [ Fri May 07, 2010 1:30 pm ] |
I like theese better. http://www.jegs.com/p/JEGS/JEGS-XHP-Tra ... 1/10002/-1 |
