It is currently Fri Jun 27, 2025 5:58 pm
Reply to topic  [ 8 posts ]
 harley engine
Post harley engine
just woundering what ever happen to the guy that built the gtr with the hd motor and if gtr is giong to offer it in the furture and if the guy that put that one to gether had any problems or did every thing work out fine? or is he going to offer the kit plates mounts etc :?:
Life is like rolling the Dice
Sat May 08, 2010 9:36 pm
Post Re: harley engine
His name is Marty aka basinlover. From what I gather it's workin great just gotta make adjustments and find all da weak links. Things like dis take a lot of research and development so don't expect to see it on da market anytime soon.
Sun May 09, 2010 7:07 am
still working on it blew the electric clutch twice and broke the crankshaft off of the back of the motor ,had trouble shearing flwheel keys, now in the process of making a FNR gear box with no plantary or electric clutch that stabs over the original crank that has a stater ring gear built on it , Harleys have no starter or ring gear that mounts on the engine. Hopeing to have something done by Caddo but doubt it, work is picking up and have been busy,Had to find a counter rotating starter and drive gears off of a yamaha 150 lower unit and fit into a homemade gear box but getting somewhere. Will take pictures when I get a little closer.
Marty
There is no replacement for displacement!!!!
Sun May 09, 2010 9:36 am
Gonna be badas when ya get done... Figured the chutch would be trouble.... Never figured that crank would break tho.... The wonderful sound of a big V-Twin... You just gotta love it.....
Uncle J 1948 holding a LT
Uncle J 1848 w/?
Sun May 09, 2010 12:33 pm
Marty, I can send you some pics of the ring gear, stub shaft, etc of the setup I started a while back if that may help.
Sun May 09, 2010 7:35 pm
Wed May 12, 2010 5:08 am
hydralics have to much loss, they are practically indestructable but heavy and I would have to cool the oil some sort off way, anyway got final piece of the puzzle yesterday found a vw starter mini that had the same bendix drive as a harley drive spocket which I think is 8 pitch so I can now start on some drawings because the starter now has to go on the backside of the gearbox, I had to find a counterclockwise starter which there aren't many. Porche and VW. The ring gears I made had too much mass and wanted to keep spining when you hit something I needed a small diameter but couldn't because I had to clear the cylinders now I think I got something that will work. Will keep posted. I also decided to go all out and going to order a 120 cu engine, 139 hp@135 ft torque at 6000 rpm, 9.8 to 1 comp so it will run on pump gas , this way I will pitch the prop as much as possible and gear up belt drive and be able to turn about 3500-4000 rpm and still have over 90 hp, they all have the same diminsions and are pretty much inerchangeable.
Marty
Thu May 13, 2010 11:29 am
:shock: This is going to be a monster... cant wait to hear what you get out of this thing.
Thu May 13, 2010 3:12 pm
Users browsing this forum: No registered users and 124 guests
