It is currently Wed Mar 18, 2026 3:07 am
Reply to topic  [ 135 posts ]  Go to page Previous  1, 2, 3, 4
 Poker1
Post Re: Poker1
Not sure if it was mentioned but use a heat gun to get the plastic Bimini fittings to fit over the conduit.
35 GTR pushing an 18' Alumitech Custom
Wed Feb 10, 2016 6:51 am
Post Re: Poker1
This thread was a lot of help as I recently built a variation of this blind. I saved a bit of money by taking some 2" X 1/4" flat bar and making the attachment hardware instead of buying the plastic bimini pieces. I simply cut the flatbar into 2" long sections and welded it to the conduit with a cheap wire welder. Also, instead of using soft straps, I slid some 3/4" PVC Tees over the couduit which allowed me to use short sections of PVC pipe to prop the blind up when in use. This way I can fine tune the height of the blind by simply changing the length of the pvc supports.
Collapsed
Raised
Raised
Fri Oct 21, 2016 7:48 am
Post Re: Poker1
I know this is an old post resurected, but guys these blinds look awesome. Defenetly going to replace my blind next year.
Have one question for Poker......Does the top half of the blind collapse for shooting? The opening seemed a bit narrow so I was just wondering.
Thanks
Fri Oct 21, 2016 9:09 am
Post Re: Poker1
I built my blind almost exactly like pokers. The top does collapse for shooting.
Fri Oct 21, 2016 9:29 am
Post Re: Poker1
Fri Oct 21, 2016 1:05 pm
Post Re: Poker1
I do have straps on the top bars. They are looped around the lower bars and hold the top bars in an over center position. I just put the blind frame back on the boat so I'll take some pics.
Sun Oct 23, 2016 6:43 am
Post Re: Poker1
I used the poker1 blind as a model a couple years back. It has been a great blind. Goes up in seconds.
Sun Oct 23, 2016 6:53 am
Post Re: Poker1
New boat 1854 Uncle J. New scissor blind.
35 SWOMP(SOLD) 90 Merc tiller/1648 Lowe Jon(Heavily Modified Transom)mod v until I get an uncle J
Sun Sep 09, 2018 7:40 pm
Post Re: Poker1
This the third scissor blind I’ve built and the first time this way and it’s unbelievable how much more sturdy it is when put up. No more pins just 2 buckles to clip in center. I plan on throwing on 2 18ft shaggy panels. I also put a piece of conduit on bottom of cordura to keep material down in the wind.
Sun Sep 09, 2018 7:46 pm
Post Re: Poker1
I've built a few of these blinds myself and no longer use the plastic buckles. I've found placing the straps at each end and using an S-hook into an eye screw at both ends of the blind rather than in the middle is way better. Plastic buckles are a PITA with gloves and get brittle in the freezing temps and placing the retention straps at both ends allows for a lot more mobility in the blind when deployed instead of having to go under the damn straps all the time.
1860 Prodigy
Sun Sep 23, 2018 8:17 am
Post Re: Poker1
^Mallards Only post some pics if you got them. Interested in your setup.
Sun Sep 23, 2018 1:53 pm
Post Re: Poker1
Wed Oct 03, 2018 9:15 pm
Post Re: Poker1
1860 Prodigy
Sun Oct 14, 2018 11:50 am
Post Re: Poker1
Very good ideas in the thread. Thanks!
Wed Aug 28, 2019 1:18 am
Post Re: Poker1
Most of the pics on this post are blurry with the photobucket logo. How can I view them? become a member of photobucket? Thanks for any feedback.
Fri Sep 13, 2019 5:02 pm
