It is currently Mon Jun 16, 2025 6:07 pm
Reply to topic  [ 16 posts ]
 Trade surface drive for outboard?
Post Trade surface drive for outboard?
My father in law gifted me a 15x52 alweld with a 35 gatortail console. Long story short, the boat doesn’t float the motor high enough, can’t get the prop high enough to run it.
I have a few options, just looking for opinions from the internet experts.
Option 1 - Trade/sell gator tail for a 25-40 hp outboard
Option 2 - Have float pods welded on. I know pods don’t allow a surface drive to perform like it should, but should be better than what I have.
Option 3 - Have a hunt deck added on. Talked to a builder in New Iberia that said adding a 18-20” hunt deck would solve the problem. His prices are very reasonable($600).
I know the alweld will never be the best hull for that motor, just looking to get some opinions from others
Thanks
Sun Feb 23, 2020 11:33 am
Post Re: Trade surface drive for outboard?
I may not be fully understanding you, but it sounds like you just need to build your transom up. (Make it a tall l transom) several people have done that to boats just like yours and it worked
Thu Feb 27, 2020 7:16 pm
You’ll prolly want a longer hull just for overall performance in the future but for now it does sound like you have a short transom model. I added 4” to my alweld transom. Just doing your transom still may not get your motor at the right angle with all the weight in the back and that short of boat. If the guy can do a hunt deck and it be strong enough I’d go that route
Thu Feb 27, 2020 9:05 pm
Oh and if you’re not running straight mud your alweld will be fine. Yea they’re not thick aluminum but you can push it out when you do get stuck
Thu Feb 27, 2020 9:06 pm
Thanks for the comments. I guess I left out that I do have a tall transom.
Sat Feb 29, 2020 1:15 pm
Tried a different trim pin hole? That boat should be fine with that engine. Maybe not ideal, but good enough.
Sat Feb 29, 2020 1:56 pm
If I knew how to post pictures I’d show you. The cavitation plate is under water when I’m in the boat. I’ll try to change the pin position, but it looks like it’ll only move up a couple inches.
Thanks
Sat Feb 29, 2020 3:50 pm
PM sent. You can text them to me if you want.
Sat Feb 29, 2020 6:18 pm
Apparently I only have the one pic of it in the water.
I’ll post some more of it not in the water.
Sun Mar 01, 2020 4:03 pm
Sun Mar 01, 2020 4:04 pm
Dude it doesn’t look like you have a bolt in the trim pin hole. I can’t be certain in your pics but it looks that way. If so, thats why you’re so dang low. There should be a grade 8 bolt that’s around 8-ish inches long running through one of those 3 holes with a sleeve over it. That’s what the motor rests on. Without it, you’re gonna be trimmed all the way down. Lift your motor up my hand (not trim) slide one in the middle hole, run it, and then go up or down one to find the optimal sweet spot.
Look where I circled on this pic and let us know if there isn’t a long bolt with a sleeve around it there.
Sun Mar 01, 2020 5:16 pm
Sun Mar 01, 2020 6:02 pm
Then why haven’t you moved it up to the top hole and tried that? It’ll make a fair difference in total trim angle
Sun Mar 01, 2020 7:16 pm
I’ll try that and see what it does. Looking at it, it does move it up a couple inches l, but I don’t think it will help much. The cavitation plate was under water without me in the boat.
Thanks for the replies
Mon Mar 02, 2020 4:57 am
Well your trim angle is low. Top Lin will help but also if you read this forum, you can find out exactly how tall the transom should be. The. Measure yours. Despite being “tall transom” that doesn’t mean it’s the right bright. If it’s not the right height, then build it up. It’s not a hard problem to solve.
Mon Mar 02, 2020 6:25 am
Change the angle of the mounting bracket by shimmimg on the outside of the boat with a couple pieces of flat bar until you figure out how thick it needs to be. Once you figure that out, you can have a wedge built. This is just an option that doesn't involve making massive changes that'll never quite be as good as getting a boat that's long enough to handle the weight you put at the rear.
Mon Mar 02, 2020 6:57 am
Users browsing this forum: Google [Bot] and 88 guests
