cb5331
 Re: Doin the steelflex thang
The way the boat is dented now, is not really hooks. Except for maybe back by the transom, couldn't really see. If you put cross braces in between, the stumps and whatnot will catch on the bracing, causing a real hook. A straight up dent, rather than something more like a tunnel. Also run a much higher risk of popping through the hull. Right now the only place a stump could really catch on anything and drive upward is on the transom.
The real "hooks" will cause a much greater loss in performance than what you got going on now. The steelflex should help a lil bit, but the metal is already stretched and will never be the same again. It sux, but it is what it is. Steelflex that sumbitch and drive the shit out of it till you finish her off.
Sat Aug 21, 2010 6:22 pm |
OwenDickeson
Sat Aug 21, 2010 7:40 pm |
Hyper Josh
Joined: Fri Dec 04, 2009 7:49 am Posts: 208 Location: Texarkana,Ar
10-4 the steelflexing will comence tomorrow. Will add more pics.
_________________ 17x54 35GTR
Sat Aug 21, 2010 8:13 pm |
DeathMetalDukk
Joined: Sat Jun 27, 2009 11:50 pm Posts: 3777 Location: Knotts Island, North Carolina.
_________________ Put yer face in the myrtles.
Sun Aug 22, 2010 7:56 am |
Hyper Josh
Got the goop on; good thing we nocked the hooks out had just enough to finish it. Now I'm baby sitting it. The leaves aren't the problem, the fukin dragonflies must be atracted to this shit! Seems to be settin up real good.
Sun Aug 22, 2010 10:29 am |
Hyper Josh
Owen, When I get this thing back together we need to get together and go ride Mercer or somethin.
Sun Aug 22, 2010 10:32 am |
SP
you better be careful the first time you back that baby into the water...it will slide right off if it is not hooked up.. You can give it soft push and will slide right of the trailer.
Sun Aug 22, 2010 3:35 pm |
Hyper Josh
Sun Aug 22, 2010 5:16 pm |
cb5331
Lookin good man
Sun Aug 22, 2010 7:27 pm |
Sando
Joined: Wed Jul 07, 2010 6:41 am Posts: 399 Location: Texarkana, AR
Hay Josh, I pick my boat Uncle J has been working on for me Friday, prolly spend the next day or so painting/rigging it and if you would like to see his work up close for whenever, if ever, you decide to get a new rig....pm me
_________________ FEAR MY WAKE!!!! http://mudmotortalk.com/mmt_v2/viewtopi ... =5&t=12134
Wed Aug 25, 2010 11:04 pm |
bbb
Joined: Wed Sep 02, 2009 2:54 pm Posts: 1554 Location: SW Georgia
I had a slick coat on mine when I bought the boat 5 yrs ago and most of it got chipped off from oyster bars.
Flipped it this spring and re-did with black Steel-flex. Hardest part was getting the old slick coat off and getting a 19x60 boat flipped over.
Unfortunately where I go, I just can't stay off the bars and i've already knocked off 30% off the steel-flex.
I had pine straw and pine cone seeds falling the day I put mine on, so I had to sit and babysit too.
_________________ 19x54 Seminole Extreme with a 35hp CDI GDSD. Mikuni. Marsh Mellow. Heads. Cam.
Thu Aug 26, 2010 9:24 am |
oncall
Joined: Mon May 10, 2010 1:46 pm Posts: 1180 Location: Georgia
looks good
_________________ 1854 Brother pulling a 36 PD viewtopic.php?f=5&t=12825 Brooks: "Tries masterbation and thank happy thots ...... purt near pulled mines off when I quit 'em ....."
Thu Aug 26, 2010 11:50 am |
Hyper Josh
Fri Aug 27, 2010 11:01 am |
