It is currently Sat Jul 19, 2025 10:05 pm
Reply to topic  [ 17 posts ]
 Painting info
Post Painting info
IM WANTING TO PAINT MY BOAT AND MOTOR THE SAME CAMO COLOR CAN I GET SOME INFO ON WHAT TO DO AND WHERE TO GET THE PAINT THANKS.
Mon Jun 07, 2010 5:22 pm
Post Re: Painting info
http://www.lockstockbarrell.com/PDF-08/ ... 090129.pdf
If your looking to order some...
If the Steel aint Flying the Birds aint Dying....
Uncle J 1948 holding a LT
Uncle J 1848 w/?
Mon Jun 07, 2010 5:27 pm
Stop yelling!!!
1754 Xtreme 35 GTR Stage 1
Mon Jun 07, 2010 6:21 pm
Thanks
Mon Jun 07, 2010 6:25 pm
Mon Jun 07, 2010 9:17 pm
Uncle J 1848 w/?
Tue Jun 08, 2010 7:21 am
I bought the Nat gear colors a few years ago. I used Mossy Oak break up stencils and it turned out great.
Tue Jun 08, 2010 9:55 pm
Instead of starting a new thread, I figured I would jump on this one.
I am painting a new boat with a basecoat. I am trying to get my hands on the kem400 from sherwin williams. Anyways, my questions was regarding the preperation. It has a white primer paint on it now and it has been on there for a couple years. What steps should I take to prep it for painting.
1. Pressure wash
2. Scrub well with dish soap
3. Pressure wash
4. Spray on Alumabrite, let soak 2 minutes
5. Pressure wash
6. Let dry
7. Paint
Does that sound OK? From my online searching, it looks like the alumabrite won't negatively affect painted surfaces. Where is the best place to get alumabrite...do they carry at automotive stores, paint stores?
Wed Jun 09, 2010 10:38 pm
Or you can spray it with regular ol vinegar and water half and half in a spray bottle, it etches and cleans the aluminum like no other, but trick is you have to let it sit for about 30min. to get the full effect and you can literally wash it off and see silver in your dirty water, its strong as hell but it get the job done like no other, just a trick of the trade i thought i'd pass on! ;)
Thu Jun 10, 2010 1:57 am
You might take a look a ALK 200, which is made by PPG. It is an automotive grade paint and holds up very well. Make sure you tell them you need a flat sheen, so they can add the proper amount of talc. Best results are sprayed thru an HVLP or cup gun.
Assumption is the mother of all f-up's!
Pro Drive 32 hp, Stage I with all the goodies
Thu Jun 10, 2010 7:36 am
I guess KEM 400 isn't sold in California...any other recommendations?
Thu Jun 10, 2010 2:52 pm
read the above post!
Thu Jun 10, 2010 6:30 pm
I just put down some A/G primer sold at the above link.... Its in the shop dring as I type.... Seems to be some good stuff.... We will see soon.... Some others on here have used it as well...
Uncle J 1848 w/?
Thu Jun 10, 2010 6:38 pm
gstics where did you find the paint?
Thu Jun 10, 2010 8:28 pm
I buy it at a local automotive paint supply store. ALK 200 is a PPG product, (pittsburgh paints). I'm sure you have an automotive paint supply store in your area, check with them. It is very important that you clarify that you want a flat sheen. Most auto paints are sold with a high gloss or semi gloss sheen. They will add talc to tone it down and there are an endless amount of colors to choose from.
I am sure there are alot of other good products out there that some members here on mmt have used but this one has worked well for me. Whatever you choose, hope it works out and post some pics.
Thu Jun 10, 2010 9:45 pm
ucsdryder,
Go on www.sherwin.com and do a search to find a Chemical Coatings store. it is not your usual neighborhood S-W store. Call them and ask if they can sell you KEM-400. If you are hearing that it is not available in California the chances are you might just be getting bad info. Don't forego the option until you hear the bad news from a qualified person in the know.
Thu Jun 10, 2010 11:04 pm
I thought I was going to get lucky as there is a CC sherwin williams store about 15 minutes from me, but the guy at the store said that it wasn't available in California, but said that was an awesome paint...
Fri Jun 11, 2010 8:23 am
Users browsing this forum: No registered users and 86 guests
