Flat and Modified V Hull
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=11735
Author:  XR-2 Fan [ Wed Aug 18, 2010 9:42 am ]
Post subject:  Flat and Modified V Hull
What's the difference in running a 35hp surface drive on a flat and modified v hull? Is it a big no no to run one on a mod v hull? Thanks
Author:  jordy [ Wed Aug 18, 2010 10:44 am ]
Post subject:  Re: Flat and Modified V Hull
viewtopic.php?f=5&t=7705&p=80325&hilit=sportsman+fab#p80325
there is a link to a review with a boat that is a semi-v/modded-v, it has a 36 PD and according to the review runs pretty good in all conditions. check it out. also its more in your opinion of what you want and the conditions you will be in most.
Author:  XR-2 Fan [ Wed Aug 18, 2010 10:49 am ]
Author:  DeathMetalDukk [ Wed Aug 18, 2010 3:11 pm ]
We don't have much objects in the water here, but a fellow down the road runs a 35MB on a 16 foot mod-v hull, it does fine, stops and starts on the mud just like the rest of them. I will tell you this though - a mod-v hull isn't as stable as a flat bottom in the water, it rocks a little more.
Author:  jordy [ Fri Aug 20, 2010 8:57 am ]
they are all gonna hook/dent no matter da style bottom. the only thing you can do is put a lil thicker aluminum bottom suck as 3/16 instead of 1/8 and maybe some extra bracing or somthing but it still will hook just not as easy.
-JordYb.
