It is currently Mon Apr 13, 2026 11:46 am
Reply to topic  [ 6 posts ]
 Who Makes T-Rail Accessories?
Post Who Makes T-Rail Accessories?
Looking for some cool shit to put in the T-Rails. Shell box, drink holder, grab bar, you name it. What makes some good stuff that I might have overlooked. Oarlocks??
Thu Mar 26, 2009 9:25 pm
Post Re: Who Makes T-Rail Accessories?
fisher boats does. google them and look under acessories. :)
Fri Mar 27, 2009 11:03 am
http://www.wareagleboats.com/accessorie ... oducts.asp
Triton uses the same t-rail as war eagle but only found war eagle accessories since they are the first ones and main ones who use it
I was told by phowler that these accessories will work in phowler boats as well
Pete Willett
WC Custom Boats - Tyler, TX
http://www.wccustomboats.com
Fri Mar 27, 2009 11:12 am
one other thing that isnt shown on that page is a small tool box that locks into the T-rail
click the link and its all the way at the bottom of page
http://www.wareagleboats.com/accessorie ... ptions.asp
Pete Willett
Fri Mar 27, 2009 11:32 am
The t-rail accessories that are made for the War Eagle rail will fit in the t-rail on Phowler boats but the angle is wrong for the accessory to sit properly. You will most likely have to bend the product to get it into the correct position. For example, I used the t-rail mounting plates for my avery quickset at the rear of my Phowler hull. The Phowler t-rail is in a vertical position as oppossed to the 45 degree angle outward of the war eagle t-rail. I had to bend the plate upward to sit horizontally to mount the blind leg bracket on it. I hope that makes sense. I will try to post a picture.
Fri Mar 27, 2009 2:10 pm
can you tell how exactly its made? would it be hard for someone to make something similar?
I've never looked at an accessory up close to be able to see how it is made...doesnt seem like much to it really just need to see up close
Pete Willett
Fri Mar 27, 2009 4:57 pm
