Register •
It is currently Sun Apr 22, 2018 6:08 pm
[ 4 posts ] |
flat bottom vs. ribbed boats for mud motors
fowlmouth
Just wondering what everyone thinks.
Do you prefer a flat bottom boat or a ribbed standard bottom boat with the use of a mud motor?
_________________ 14x48 Polar Kraft 27hp Beavertail LT 25hp Yamaha
Thu Oct 21, 2010 3:50 pm |
dog walker
Joined: Tue Jan 13, 2009 6:08 pm Posts: 5282 Location: Meraux,La.
 Re: flat bottom vs. ribbed boats for mud motors
I had ran my motor on a custom built boat that had 3 crimps and it turned on a dime. In the chit it would perform well. Now to compare it to a flat bottom hull,the flat bottom is better in straight mud because of the drag issues. This is just my opinion though
Thu Oct 21, 2010 3:58 pm |
Woodiebuster
Joined: Wed Mar 03, 2010 7:00 pm Posts: 6057 Location: Choudrant, La
like dw said, its gunna hurt you in the mud because of more drag. If your like me and just run shallow water, stumps, and grass then a ribbed bottom doesnt affect you that much (unless you are in some really thick grass) Where a mud hull would really shine for me is for the thicker construction and longitudinal braces so it doesnt get beat up in stumps.
Thu Oct 21, 2010 6:06 pm |
idabilly
Joined: Sat Jan 17, 2009 7:17 pm Posts: 590 Location: Idaho
I have owned five different boat hulls on which I have hung shorttail mud motors. Four were flat and smooth bottom with no crimps or keels. One (bad idea) was a shallow deadrise modified V. That boat didn't last long. I will never again run a mud boat with crimps or keels. But then again, I have frequent need to go shallow over either hard mud, soft mud, thick vegetation and shallow gravelly shoals.
If you are in relatively deep water and are buying a mud motor for weeds only then knock yourself out with a non-smooth bottom boat.
Fri Oct 22, 2010 9:28 am |
[ 4 posts ] |
