It is currently Wed Jun 25, 2025 7:28 pm
Reply to topic  [ 12 posts ]
 ice beating boat
Post ice beating boat
had the 1648 war eagle w/ pd out bustin 1 in ice the other morning and when we got back to the ramp noticed dents on both sides towards the front of the boat about 2 foot long just banged in. ive had this boat in a lot thicker ice than this without a scratch, with an outboard. didnt know if the motor had anything to do with it on this boat or not. we did have 2 guys in the front, and there was when we were in thick ice. just trying to get some insight to what is going on here
Thu Dec 09, 2010 3:35 pm
Post Re: ice beating boat
i'd try sliding some weight back.
Gave up hunting ducks and started underwater basket weaving!
Thu Dec 09, 2010 3:53 pm
Not saying I know anything about it
But what the hell do you know about running in ice
Aucoin 20X48 36pd
Lock your wife and your dog in the garage for an hour. Then open it and see
who's happy to see you.
Thu Dec 09, 2010 4:01 pm
I don't lol but seem like it would help ..
Thu Dec 09, 2010 4:07 pm
"You may all go to hell, as for me I'm going to Texas" D. Crockett
What is best in life?
To crush your enemies, to see them driven before you, and to hear the lamentations of their women.
Thu Dec 09, 2010 6:28 pm
i didn't mean every body , like even through out the weight, just not all the weight on the nose takin all the pressure.
Thu Dec 09, 2010 6:31 pm
last year we had a good freeze at the duck hole which is rare down here, so my ice experience is very limited, but i did learn alittle somthing last year. i noticed that the lane we busted open going to the area we hunt had started to refreeze just outside the boat lane causing the sides of the ice to get twice as thick as the undisturbed ice from the water splashing up and refreezing. i bumped the edge of refrozen ice with the side of the boat while i was making a turn and thought i tore a hole in the hull. as long as i kept the front of the boat up and hit it straight on i could break thru without hurting the boat.
maybe it was just the way you were hitting the ice?
INSTANT REVERSE .....its like a power window, you could live without it, but why bother!!!!
got two wooden nickels and a rabbit's foot, livin on luck like a small time crook. ;)
i wear my soul like alligator skin, hard as leather with a toothy grin.
:mrgreen:
Wed Dec 15, 2010 4:40 pm
The keys that I have found are to not break ice with the front of boat, unless it is skim ice, otherwise position your load so the nose runs up on the ice and you are breaking ice with bottom of boat. Also when you are turning make long sweeping turns otherwise you might actually tear a hole in the side. If you run the boat up on the ice just walk everyone to the back until it breaks through. We bust ice every year and at times it gets interesting. I will say the Mudboat design does not break ice nearly as well as the MV hulls. the mm hull wants to ride up and over the ice so up have to go much slower.
2060 Phowler Extreme
Tandem Axle All Aluminum Trailer
Pro Drive 36 Stock + EVT loud exhaust
Sat Dec 18, 2010 10:13 pm
up here in the north east we have to break ice alot we have found with the flat bottom boats you need to get the weight back torwards the rear of the boat ride the boat up on the ice past the rake, then step forward and then repeat this over again, also depends on the thickness of the ice ,its a long process and its sounds like hell we were busting 2" ice, this week it took 1 hour just to get to the hole then ran the boat in circles to push out any ice in that area when we were done it was well worth it :D
Life is like rolling the Dice
Sun Dec 19, 2010 7:23 am
First post.......Ya-hooooooo
Hey guys, Im a new b on the block, so take it easy on me!
Question, how hard is ice on your prop.? I busted through about 1/2 mile until I put the boat on a 6' deep ice jam. SO, not fun getting out in 8 degree weather at 5 am.
I did manage to get out in about a 1/2 hour and then ran circles around those outboard losers! Sorry, Im ALL about these motors and boats!
Stump Jumper 17x54 w/duck deck
GTR 35 stage II
Stump Jumper Rep. for IN (Stumpjumperboats.com)
Athens archery Bowfishing Pro Staff/Field Rep.
Mon Dec 20, 2010 10:13 am
Your dents are from having to much weight in the front, you want to try and keep the rake of the boat above the ice. The dents are from banging the sides into the hard edges of the broken trail, it is hard on a .100 hull to be bounched side to side in the ice.
PW
Paul V. Willging - Owner
Phowler Boat Company
Illowa Marine
Mon Dec 20, 2010 11:57 am
We run alot of Ice up here and one thing is for certin. Ice will constantly build pressure over time and you will release that pressure as you are driving through it. If you have too much weight up front the ice could crush your bow by squeezing the sides.
Last year we ran into a hole busting 2-3" of ice and when we came out 4 hours later you could not even see our track. The two ice flows that we made by cutting it in half had pushed completely together. The water dropped about 4" the night before. Thats alot of pressure squeezing on a hull.
Illowa Marine - Home of Illowa Pro-Drive and the Phowler Boat Company
Wed Dec 22, 2010 6:38 am
Users browsing this forum: No registered users and 133 guests
