Removing hydroturf? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=29565 |
Author: | Grabwad [ Tue May 29, 2012 6:32 pm ] |
Post subject: | Removing hydroturf? |
Any easy way to remove hydroturf? |
Author: | SmokeEater829 [ Tue May 29, 2012 6:52 pm ] |
I doubt there is an easy way. I had to remove it from a fiberglass boat and we used a belt sander! Bought a bunch of cheap belts from harbor freight and went to town! Messy as hell, but it worked. |
Author: | cb5331 [ Tue May 29, 2012 6:54 pm ] |
Post subject: | Re: Removing hydroturf? |
Gasoline will eat that shit right off. |
Author: | Grabwad [ Tue May 29, 2012 7:16 pm ] |
Negative on the gas, ate my paint but that turf ain't givin up. This decision was a total failure so far! Crap!! |
Author: | cb5331 [ Tue May 29, 2012 7:20 pm ] |
Author: | Team Camo [ Tue May 29, 2012 7:22 pm ] |
acetone & let it get to the glue, but why are you taking it off? |
Author: | Grabwad [ Tue May 29, 2012 7:46 pm ] |
Why? Can't answer that in anyway that makes sense. LOL ! Bc I'm a dumbarse is only legitimate answer! I'm repainting and decided to replace with new turf. The glue is 3M backing. I may have used cement as well on corners, I can't remember. |
Author: | med [ Tue May 29, 2012 7:48 pm ] |
In the middle of removing mine. It had the 3m adhesive backing. Park it in the sun and work on it then. It will peel up if you do it SLOWLY. I imagine if I have to do this again I will soak it with gas, set it on fire and hope for the best. |
Author: | Team Camo [ Tue May 29, 2012 7:49 pm ] |
Author: | med [ Tue May 29, 2012 7:50 pm ] |
Post subject: | Re: Re: Removing hydroturf? |
Author: | quackconsumer [ Tue May 29, 2012 8:42 pm ] |
I like the fire idea. Just be sure to have a way to quickly extinguish it. You don't want the aluminum to get too hot. |
Author: | BayouRunner [ Tue May 29, 2012 8:55 pm ] |
Try using a floor scraper, the ones with the replaceable razor blades. Then finish up with a solvent to get the rest off. Lots of manual labor! |
Author: | Grabwad [ Wed May 30, 2012 4:08 am ] |
I'm thinking about a grinder with a wire wheel as well. I'll try a scraper with razors. |
Author: | Will [ Wed May 30, 2012 4:33 am ] |
I ripped up about a 2 foot square of mine the other day to rearrange my battery placement and said right then the rest will have to wear off before I try to get it up. I couldn't get it to peel in sheets, it kept tearing and I'd have to get it started again. It has the 3M backing. Turbo torch it! |
Author: | Richard in LA [ Wed May 30, 2012 5:59 am ] |
I have heard its best to use one of these: I have one, just havent had the time to change out my turf, so I can't report on its effectiveness. I've been told that it takes the turf off like shearing a sheep. |
Author: | dead duk [ Fri Jun 01, 2012 9:28 am ] |
Has anyone tried the 3M adhesive remover? I have used it on other adhesives and it is the best remover I have ever seen. Do not spray it on any adhesive parts you want to keep in place...it will take all adhesive off in seconds. May want to try it. |
Author: | Grabwad [ Sat Jun 02, 2012 8:57 pm ] |
I used a grinder, was a pain but I got it done! |
Author: | Frog [ Thu Jun 07, 2012 7:20 am ] |
Author: | Ruddyduck [ Thu Jun 07, 2012 8:15 am ] |
I removed it off the floor sheets in a 1848. This is why I will never put it in my boats. With all the beating I put my boat through, there are times I need to get under the false floor to do repairs and beat out hooks. I used a scraper to get the bulk of it off, then tried acetone which didn't work worth shit, then threw the floor sheets in the sand blaster which didn't work worth shit, then finished up with a DA to get the last of it. If I would have added up my time new aluminum would have been much cheaper! It is great stuff on your feet, but I'll just stick to wearing flipflops!!! |
Author: | med [ Thu Jun 07, 2012 9:06 am ] |
I pulled most of mine up but it left little pieces all over. I then used an attachment for a drill that has the hard sponge looking wheel and it worked great. |
Author: | CAJUN OUTLAW [ Thu Jun 07, 2012 12:26 pm ] |
remove the fuel tank and use a torch and a barnacle scraper.have the water hose on standby. |
Author: | DMC [ Fri Jun 08, 2012 5:26 pm ] |
Try some 3M addhesive remover. |
Author: | duckzbuckz365 [ Fri Jul 13, 2012 8:41 pm ] |
go to your auto shop and buy some gasket remover. that stuff will eat up any sticky shat |
