It is currently Fri Jan 23, 2026 6:36 am
Reply to topic  [ 6 posts ]
 Best boat to buy for a 27hp SD motor
Post Best boat to buy for a 27hp SD motor
Need some input on what type of boat to get for my 2012 27 hp SD motor. I have it on a 2009 alumacraft waterfowler 16ft, But it is to heavy and slow. What type boat should i get??
Tue Jul 24, 2012 3:02 pm
Post Re: Best boat to buy for a 27hp SD motor
What's so heavy about your alumacraft isn't it .100 gauge aluminum most mud hulls are built outta .125
Tue Jul 24, 2012 3:38 pm
What kind of speeds are you getting
Tue Jul 24, 2012 4:13 pm
Ok im new to this stuff u can say im a green horn that needs help. I dont no the specs to my boat but can tell u with fuel in the back two battery in the back and in open water i cant even plane out. (speed less then 15 mph im guessing) i no that stuff needs to go to the front but dont have no room. like i said dont no much but when a 1436 jon boat with a 10hp go-devil long shaft can out run u and put u in the dust to me there is something wrong with that picture. But if thats normal well then ok but i dont think it is.
Tue Jul 24, 2012 4:37 pm
WEll idk the width of your boat but I would say a longer boat would deffinely help something in the 18x40-42 range as Owen said in your other post. These boats run Better on a longer boat whoever told ya short an wide is best for a surface drive was mistaken.
Tue Jul 24, 2012 4:41 pm
I would not go one inch shorter than 17 feet, and I would personally look at 44-48 inch wide boats. Then it will be the perfect size for when you upgrade motors. Not to mention perform right with the motor you have now.
Sent using my bag phone
Tue Jul 24, 2012 6:05 pm
