It is currently Fri Jan 23, 2026 6:40 am
[ 4 posts ] |
converting a ribbed to a smooth bottom?
waterfowl1
Joined: Sun Jul 17, 2011 12:02 pm Posts: 335 Location: hayward, wi
how about welding a sheet of aluminum over the ribs and to the edges. that would make a bit of an angle from the most outside ribs to the side edges of the boat. thoughts?
_________________ Wish in one hand and shit in the other, see which one gets filled first. If yur gonna be stupid, you might as well be smart about it.
| Mon Jul 23, 2012 8:03 pm |
Woodiebuster
 Re: converting a ribbed to a smooth bottom?
weld a peice of square tubing on each edge of the bottom and them weld the slick bottom over the runner and all, you would have a seal welded double bottom.
| Mon Jul 23, 2012 8:44 pm |
Cast&BlastMI
Joined: Tue Jul 17, 2012 2:21 pm Posts: 24 Location: Southern Michigan
Out of curiosity, why are smooth bottom boats sometimes preferred over ribbed boats?
| Tue Jul 24, 2012 3:53 pm |
Woodiebuster
Less drag, you slide over mud and grass much easier. In stumps the boat will slide off instead of hanging up.
Also, if you have to turn it around in mud or grass when hunting you will definetly notice a difference.
| Tue Jul 24, 2012 8:39 pm |
[ 4 posts ] |
