It is currently Mon Jul 07, 2025 9:57 am
[ 6 posts ] |
dadazzsaleen
Joined: Tue Nov 09, 2010 11:24 pm Posts: 743 Location: Mandeville, LA
 Boat building ?
Any cons to a boat that the sides and bottom are welded together, rather then the sides & bottom being one piece bent?
_________________ [Stage 2.5]
Fri Jan 25, 2013 7:49 pm |
CCC
 Re: Boat building ?
It's 2 more welds that could fail. My boats welded and its held up good.
Sat Jan 26, 2013 5:57 am |
nasty
 Re: Boat building ?
More boats are built by being welded together than being bent. It's usually a double weld(outside and inside) what you need to lookout for is a weld being down the center of the bottom, that is a problem. But the side, that's very common, prolly the most common lol, you've got nothing to worry about.
Sat Jan 26, 2013 7:41 am |
banded-mallard
 Re: Boat building ?
I have always wondered this as well. The weld is usually the weakest part and the first to crack. I would think a crimped hull would be a little stronger plus it cuts out anywhere from 4 - 17 to 19 foot welds inside and out. If you don't know what your doing, that much heat in a given area will warp your shit. Just a thought.
Sat Jan 26, 2013 8:09 am |
CCC
 Re: Boat building ?
My boats welded and its doin great. 90% or more mud boats that I've seen are welded
Sat Jan 26, 2013 12:06 pm |
Cumminsdiesel69
Joined: Thu Feb 02, 2012 9:50 am Posts: 350 Location: Thibodaux, LA
 Re: Boat building ?
IMO a boat that has welded square chine is more solid than a one piece hull if done properly. And is gonna be straighter also.
_________________ 2013 1846 Gator Series w/ 35 GTR Hoyt's heads and gutted stock exhaust
Sat Jan 26, 2013 5:26 pm |
[ 6 posts ] |
Users browsing this forum: No registered users and 81 guests |
