It is currently Wed Jul 09, 2025 3:37 am
Reply to topic  [ 22 posts ]
 Trailer bunks
Post Trailer bunks
Laying flat or vertically? Or does it matter? Obviously horizontally would give you more surface area. But I just bought a trailer and the bunks are mounted vertically. What's the disadvantages of having them vertical?
Fri Jan 25, 2013 6:53 pm
Post Re: Trailer bunks
Lay them horizontal Standing them up will eventually bend the brackets and be a pain.
Aucoin 20X48 36pd
Lock your wife and your dog in the garage for an hour. Then open it and see
who's happy to see you.
Fri Jan 25, 2013 9:39 pm
Horizontal. Sitting lower on the trailer makes it easier to launch in shallow water. Don't have to back in as far to float the boat.
Sat Jan 26, 2013 4:03 pm
lay em flat like everyone else said....
Mine has the outdoor carpet you can get from home depot (roll was $14 bucks and did both of my 2x6s) and its pretty rugged.
Mon Jan 28, 2013 2:53 pm
Never though of that for some reason. I'm in need of fixing mine up. The ice really tears at mine.
Mon Jan 28, 2013 3:00 pm
MMT Moderator
I will never use carpet again on any aluminum hull. I run too much saltwater and the carpet holds moisture to the hull. This will lead to pitting in areas. I removed my carpet and installed some plastic bunk covers from McClain.
GTB 1860 w/ 2019 GTR40XD-HO
Mon Jan 28, 2013 3:22 pm
Mon Jan 28, 2013 3:34 pm
X2 on synthetic boards. More $ up front, but you'll never have to replace them. I filled in the counter sunk bolt holes with 2 part epoxy putty and sanded smooth. That way the bolts can't work themselves loose and potentially scratch my hull.
Mon Jan 28, 2013 4:20 pm
1854 InstaGator
35 GTR w/ carb and MM exhaust
"Addicted is an understatement"
*GEAUX TIGERS*
Mon Jan 28, 2013 4:32 pm
Great point! The pitting is probably located where your carbon steel bolts are on the opposite side of the carpet. It will create a galvanic corrosion cell at and around where the bolt is located if the carpet is saturated with salt water.
Salt water is the electrolyte between the carbon steel bolt and aluminum hull if the water creates a "circuit" so to speak.
Mon Jan 28, 2013 4:40 pm
Tue Jan 29, 2013 10:44 am
MMT Moderator
Tue Jan 29, 2013 11:01 am
Tue Jan 29, 2013 11:11 am
Lol I doubt it
Tue Jan 29, 2013 11:17 am
MMT Moderator
LMAO heck no mines not from Harbor Freight. You get what you pay for people.... It's a McClain Trailer I mentioned that in my post. http://www.mcclaintrailers.com
Tue Jan 29, 2013 11:29 am
Damn WEA, how do you get a trailer custom built when ordering from a large trailer company like that? Harbor Freight lets you select the width by just adjusting the tie wraps that hold the frame together, plus it saves you a ton of money! Only downfall is that you can't put it in the water.
Tue Jan 29, 2013 11:52 am
Tue Jan 29, 2013 12:54 pm
"There's nothing a duck hunter hates more than another duck hunter"
Custom 17x48 with a new Gen III Prodrive.
Tue Jan 29, 2013 1:05 pm
Come up here and hunt geese with me friday on the river and I will show you...lol
Tue Jan 29, 2013 1:15 pm
Tue Jan 29, 2013 3:22 pm
Can someone tell me disadvantages of having them vertically? Dents? Hooks?
Tue Jan 29, 2013 4:40 pm
Wed Jan 30, 2013 9:20 am
Users browsing this forum: No registered users and 102 guests
