Boat building ? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=36859 |
Author: | dadazzsaleen [ Fri Jan 25, 2013 7:49 pm ] |
Post subject: | Boat building ? |
Any cons to a boat that the sides and bottom are welded together, rather then the sides & bottom being one piece bent? |
Author: | CCC [ Sat Jan 26, 2013 5:57 am ] |
Post subject: | Re: Boat building ? |
It's 2 more welds that could fail. My boats welded and its held up good. |
Author: | nasty [ Sat Jan 26, 2013 7:41 am ] |
More boats are built by being welded together than being bent. It's usually a double weld(outside and inside) what you need to lookout for is a weld being down the center of the bottom, that is a problem. But the side, that's very common, prolly the most common lol, you've got nothing to worry about. |
Author: | banded-mallard [ Sat Jan 26, 2013 8:09 am ] |
I have always wondered this as well. The weld is usually the weakest part and the first to crack. I would think a crimped hull would be a little stronger plus it cuts out anywhere from 4 - 17 to 19 foot welds inside and out. If you don't know what your doing, that much heat in a given area will warp your shit. Just a thought. |
Author: | CCC [ Sat Jan 26, 2013 12:06 pm ] |
My boats welded and its doin great. 90% or more mud boats that I've seen are welded |
Author: | Cumminsdiesel69 [ Sat Jan 26, 2013 5:26 pm ] |
IMO a boat that has welded square chine is more solid than a one piece hull if done properly. And is gonna be straighter also. |
