| Hooks http://mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=39051 |
| Author: | rob_E [ Mon Mar 25, 2013 11:01 am ] |
| Post subject: | Hooks |
Is a gatortail .125 hull thick enough on the bottom to prevent hooks and dents within reason? I mentioned the name because i dont know how they are braced. I will ocasionally run up on a stump but not every day. |
| Author: | eljefe [ Mon Mar 25, 2013 11:04 am ] |
| Post subject: | Re: Hooks |
yep.....125 and longitudinal runners help prevent hooking, but it always depends on how hard ya hit that stump. |
| Author: | The Shafer [ Mon Mar 25, 2013 11:35 am ] |
they all will eventually hook and dent. You're not in East Texas so just get what you want and run it like hell. |
| Author: | BayouBuster [ Mon Mar 25, 2013 11:50 am ] |
As long as you use common sense and don't run through stump fields you'll be fine. |
| Author: | MALLARDSX2 [ Mon Mar 25, 2013 12:09 pm ] |
Mine wont hook and dent...lol |
| Author: | CootSlayerRMFT [ Mon Mar 25, 2013 12:41 pm ] |
You lookin at a new rig, Robe??? |
| Author: | rob_E [ Mon Mar 25, 2013 12:55 pm ] |
yes sir. |
| Author: | Gameover [ Mon Mar 25, 2013 2:43 pm ] |
could of gave a man a warning its not easy to find a back of the pack buddy replacment these days expecially with all the kool-aid drinking motors |
| Author: | CootSlayerRMFT [ Mon Mar 25, 2013 8:51 pm ] |
What are you talking about??? You're one of em now! |
| Author: | Gameover [ Tue Mar 26, 2013 4:53 am ] |
Haha true true |
| Author: | Claycountycracka [ Wed Mar 26, 2014 1:28 pm ] |
lets see some hook pictures... |
| Author: | North LA Hunter [ Wed Mar 26, 2014 1:32 pm ] |
1/8 will hook if you hit stumps eventually. If its every once and a while I wouldn't worry about it but if its a every day thing I would go thicker. I've run 2 1/8 boats and 1 .100 boat and from now on I will have 3/16. But I hit stumps just about every time I get in the boat up here. Sent from my beeper |
| Author: | WhoDat88 [ Wed Mar 26, 2014 1:36 pm ] |
| Author: | North LA Hunter [ Wed Mar 26, 2014 1:40 pm ] |
| Author: | OwenDickeson [ Wed Mar 26, 2014 1:51 pm ] |
| Author: | Claycountycracka [ Wed Mar 26, 2014 1:53 pm ] |
^x2 |
| Author: | caddobrook [ Wed Mar 26, 2014 2:51 pm ] |
| Author: | WhoDat88 [ Wed Mar 26, 2014 4:32 pm ] |
| Author: | Full Throttle [ Wed Mar 26, 2014 4:37 pm ] |
| Author: | WhoDat88 [ Wed Mar 26, 2014 4:47 pm ] |
| Author: | JLACOUR [ Wed Mar 26, 2014 4:55 pm ] |
Here is a gatortail boat. Is this a good design? |
| Author: | Full Throttle [ Wed Mar 26, 2014 4:56 pm ] |
The only point I will make is that it doesn't take a dangerous situation to hook a 1/8" hull with 5 longitudinal braces. That was a false statement. If you run up here in texas corp lakes, it takes 7 braces with a 3/16" bottom minimum. Just about every trip out it's very possible you will hit multiple stumps just below the surface that will jack up the bottom. If I was down in south la, 1/8" works just fine. |
| Author: | WhoDat88 [ Wed Mar 26, 2014 5:04 pm ] |
| Author: | creekwader [ Wed Mar 26, 2014 5:07 pm ] |
yall need glasses my boat drafts about three inches sitting still less on step. stump under the surface is a little bump. |
| Author: | Gameover [ Wed Mar 26, 2014 8:30 pm ] |
| Author: | fishnmoney [ Wed Mar 26, 2014 8:40 pm ] |
Robbie, Isn't your current gator tail boat .125? You plan on going bigger? |
| Author: | Gameover [ Wed Mar 26, 2014 8:43 pm ] |
Y'all realize this post is from 2013 right? |
| Author: | North LA Hunter [ Wed Mar 26, 2014 8:45 pm ] |
| Author: | WhoDat88 [ Wed Mar 26, 2014 9:31 pm ] |
| Author: | Quackkillz [ Thu Mar 27, 2014 12:02 am ] |
And there was exactly 1 year to the day between post, 3-26-13 then the next post was 3-26-14 Sent from my SAMSUNG-SM-N900A using Tapatalk |
| Author: | dog walker [ Thu Mar 27, 2014 5:17 am ] |
I've seen what La built .125 hulls look like after a few years in east Tx lakes, they get hooked at the transom and grooved between the braces. |
| Author: | Claycountycracka [ Thu Mar 27, 2014 7:18 am ] |
i just want to see some bad hooked hulls....anyone? |
| Author: | North LA Hunter [ Thu Mar 27, 2014 7:30 am ] |
| Author: | Delta1389 [ Thu Mar 27, 2014 8:56 am ] |
Just wait. I can get some pics. |
| Author: | CootSlayerRMFT [ Fri Mar 28, 2014 2:25 am ] |
Owen for the win... Sent from my iPhone using Tapatalk |
| Author: | DeltaRunner [ Fri Mar 28, 2014 3:04 am ] |
My 1648 GD boat. I beat the hooks out with a dead blow. Noticed the other day that I cracked two of the welds on the runners. It never ends. |
| Author: | OwenDickeson [ Fri Mar 28, 2014 8:06 am ] |
I wish I had some pictures of my Pro-Drive boat. You could have flipped that thing over, and sprayed water on it, and had pools deep enough for gold fish to swim around in. |
| Author: | med [ Fri Mar 28, 2014 8:18 am ] |
Dude I know has a gatortrax and if I hadn't been riding in it I would have bet 500$ it wouldn't plane out. Looks like you flipped it and beat it with a sledge hammer. |
