It is currently Fri Dec 19, 2025 5:34 pm
Reply to topic  [ 6 posts ]
 Need Help
Post Need Help
I just got my first mud motor rig and need suggestions or solutions....
I have a 1448 fisher all welded boat with pods on the back, and a 23 gator tail surface drive.
The problem im having.... When running, water splashes up or well it roosts up from the sides of the motor(both sides between the pods and the bottom of the motor) right by the transom and splashes into the boat. Any help on fixing this would be appreciated
Fri Sep 25, 2009 9:59 pm
Post Re: Need Help
Are you sure you have the right transom height for that motor???
1754 GT EXTREME 37EFI
Sat Sep 26, 2009 7:18 pm
Post Re: Need Help
17x48 extreme stage 2 GTR
Sat Sep 26, 2009 7:33 pm
Post Re: Need Help
That is what i was thinking, cuz the motor is mouted on a mini gil bracket. I appreciate the help. i check it out and see how it works out.
Sat Sep 26, 2009 8:28 pm
Post Re: Need Help
IT doesn't sound like you have the right setup there padna...Find out if you have a short shaft or long shaft motor and ask what the transom height should be for your motor and measure the boat.. And cut or weld as needed!!!
Sat Sep 26, 2009 8:32 pm
Post Re: Need Help
If the motor/transom hieght is correct you may have to move the pin in the mounting bracket,this may get the bottom of the belt housing out of the water.
Sun Sep 27, 2009 4:20 pm
