| trailer bunk boards ? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=51627 |
| Author: | deadcypress [ Thu Mar 20, 2014 7:01 am ] |
| Post subject: | trailer bunk boards ? |
can I use composite boards from lowes ? will it hurt the bottom of my boat ? ,I have gator glide on it |
| Author: | MNGunner [ Thu Mar 20, 2014 7:13 am ] |
| Post subject: | Re: trailer bunk boards ? |
I've heard people that tried the composite say they weren't rigid enough. I used treated 2x4s that I capped with 1x4 PVC boards. On top of that, I then put plastic caps they make for bunk boards. Before I had jut the plasic caps on top of treated, and at every seam, my hull was being discolored by the treated wood chemicals leaching. |
| Author: | Bigrich [ Thu Mar 20, 2014 7:13 am ] |
I haven't heard any negatives from composite boards. |
| Author: | MDMarsh [ Thu Mar 20, 2014 7:37 am ] |
I have my trailer set up like MNGunner. PT 2x4s with a PVC 1x4 cap. I dont have the slick caps on top of mine though. I put the wood grain pattern facing up figuring it was less surface area to grab and seemed more slick than the smooth side. Works great for me. |
| Author: | BayouStateHunter [ Thu Mar 20, 2014 7:12 pm ] |
Doesn't the boat dr sell the plastic caps to put over the runners? |
| Author: | AKA Freshwaterkilla [ Thu Mar 20, 2014 7:22 pm ] |
If ur talking about the composite deck boards them suckers are kind of ruff almost like sand paper especially when wet for added foot traction lol I bet they would hold up but they make a board at lowes that is solid PVC its a 1/2" x 10"wide by 8 10 or 12 ft long it has a wood grain looking side to it but is solid plastic I put it on my trailer and it holds up awesome I just put treated 2x12 under it and bolted straight to the trailer Sent from my iPhone using |
| Author: | BoatDR [ Thu Mar 20, 2014 7:48 pm ] |
| Author: | BoatDR [ Thu Mar 20, 2014 7:55 pm ] |
| Author: | AKA Freshwaterkilla [ Thu Mar 20, 2014 8:44 pm ] |
| Author: | HUNT4DEER [ Fri Mar 21, 2014 8:00 am ] |
I used some on a bass tracker years ago. The boards I used were 2 inches thick. They worked well and didn't have any effect on the bottom. They did sag after while. Took them off and ripped a 1 inch deep 1/8 " grove in or. Added a length on angle under it and it took out the sag |
| Author: | Shieldsz [ Thu Mar 27, 2014 1:54 pm ] |
See some people using like a 4x6 with the 6" side up and down. what would be the advantage? |
