poke_chop666
Joined: Sat Apr 06, 2013 12:07 am Posts: 487 Location: port barre,la
 What's these called?
Where can I get these and what are they called?
_________________ 25 yamaha pushing a 1642 welded flat 20 hp go-devil longtail for hunting.
Thu Mar 27, 2014 5:10 pm |
marshmadnes08
Joined: Tue Oct 09, 2012 6:11 pm Posts: 265 Location: SETX
 Re: What's these called?
Bimini hardware. http://www.duckworksbbs.com/hardware/bimini/index.htmSent from my SM-N900V using Tapatalk
Thu Mar 27, 2014 5:12 pm |
marshmadnes08
You building a boat blind?
barnes_53
Bimini top cap attached to a bimini top slide
If you are building a boat blind here ya go...enjoy. It is a link to my parts list I put together to build my blind using bimini hardware.
Thu Mar 27, 2014 5:13 pm |
poke_chop666
Yea
Thu Mar 27, 2014 5:17 pm |
poke_chop666
Wouldn't have it at lpwes?
Thu Mar 27, 2014 5:18 pm |
jldsc
I got all mine off of amazon...a West Marine may have it if you have one local.
Sent from an Apple Tree..
Thu Mar 27, 2014 5:38 pm |
lizard55033
Joined: Thu Aug 26, 2010 7:06 pm Posts: 512 Location: Burnsville,MN
neat info
_________________ Running an 1860 Gator Tail Extreme with a 25 Horse Merc
Thu Mar 27, 2014 5:42 pm |
marshmadnes08
I made mine last year.
Thu Mar 27, 2014 5:45 pm |
marshmadnes08
Thu Mar 27, 2014 5:46 pm |
fowllife08
Joined: Sun Sep 18, 2011 7:25 pm Posts: 3676 Location: down in da flats, LA
West marine is where i got mine. Amd the picture of marsh madness' frame is why ur gonna need a welding machin and a stick of 1\2
_________________ 35 GTR chasin a BBC 1848
Thu Mar 27, 2014 6:09 pm |
marshmadnes08
Def need to weld. The coupling didn't hold up. I welded mine up.
Thu Mar 27, 2014 6:22 pm |
poke_chop666
Caleb u ever measured ur blind to see if it will fit? I may just buy yours
Fri Mar 28, 2014 3:55 am |
fowllife08
Fri Mar 28, 2014 4:28 am |
poke_chop666
Ordered the stencils last night. It will be painted but gonna put a blind too.
Fri Mar 28, 2014 4:54 am |
fowllife08
Fri Mar 28, 2014 5:11 am |
rob_E
Joined: Wed Jan 25, 2012 12:03 pm Posts: 1763 Location: Prairieville, LA
Poke Chop you can get the Bimini Hardware at most boat Dealers that sell parts I got mine at Thomas Marine in Gonzales, LA Everything I needed was in stock.
_________________ 18X54 CC & 35 GTR w/ Hoyts Stage 1
Fri Mar 28, 2014 7:42 am |
MDMarsh
Joined: Tue Jun 25, 2013 1:23 pm Posts: 289 Location: Eastern Shore MD
Your gonna have to bore the hardware out a little to fit the 3/4" conduit. A dremel with a small cutting bit will work just fine. Just a few passes around the inside. Also like these guys are saying get some 1/2" and cut it into 3' sections. insert 18" into the end of the 3/4" and tack it in place. Then slide a second stick of 3/4" and weld all the way around. 100Xs better than couplings.
Fri Mar 28, 2014 8:43 am |
poke_chop666
Terrain phantom- ground shadow.
Fri Mar 28, 2014 12:29 pm |
poke_chop666
Fri Mar 28, 2014 12:30 pm |
