It is currently Mon Jun 23, 2025 12:24 am
Reply to topic  [ 20 posts ]
 What's these called?
Post What's these called?
Where can I get these and what are they called?
25 yamaha pushing a 1642 welded flat
20 hp go-devil longtail for hunting
Thu Mar 27, 2014 5:10 pm
Post Re: What's these called?
Bimini hardware. http://www.duckworksbbs.com/hardware/bimini/index.htm
Sent from my SM-N900V using Tapatalk
Thu Mar 27, 2014 5:12 pm
Profile YIM
You building a boat blind?
Profile YIM
Bimini top cap attached to a bimini top slide
If you are building a boat blind here ya go...enjoy. It is a link to my parts list I put together to build my blind using bimini hardware.
Thu Mar 27, 2014 5:13 pm
Yea
Thu Mar 27, 2014 5:17 pm
Wouldn't have it at lpwes?
Thu Mar 27, 2014 5:18 pm
I got all mine off of amazon...a West Marine may have it if you have one local.
Sent from an Apple Tree..
Thu Mar 27, 2014 5:38 pm
neat info
Running an 1860 Gator Tail Extreme with a 25 Horse Merc
Thu Mar 27, 2014 5:42 pm
I made mine last year.
Thu Mar 27, 2014 5:45 pm
Profile YIM
Thu Mar 27, 2014 5:46 pm
Profile YIM
West marine is where i got mine. Amd the picture of marsh madness' frame is why ur gonna need a welding machin and a stick of 1\2
35 GTR chasin a BBC 1848
Thu Mar 27, 2014 6:09 pm
Def need to weld. The coupling didn't hold up. I welded mine up.
Thu Mar 27, 2014 6:22 pm
Profile YIM
Caleb u ever measured ur blind to see if it will fit? I may just buy yours
Fri Mar 28, 2014 3:55 am
Fri Mar 28, 2014 4:28 am
Ordered the stencils last night. It will be painted but gonna put a blind too.
Fri Mar 28, 2014 4:54 am
Fri Mar 28, 2014 5:11 am
Poke Chop you can get the Bimini Hardware at most boat Dealers that sell parts I got mine at Thomas Marine in Gonzales, LA Everything I needed was in stock.
Fri Mar 28, 2014 7:42 am
Your gonna have to bore the hardware out a little to fit the 3/4" conduit. A dremel with a small cutting bit will work just fine. Just a few passes around the inside. Also like these guys are saying get some 1/2" and cut it into 3' sections. insert 18" into the end of the 3/4" and tack it in place. Then slide a second stick of 3/4" and weld all the way around. 100Xs better than couplings.
Fri Mar 28, 2014 8:43 am
Terrain phantom- ground shadow.
Fri Mar 28, 2014 12:29 pm
Fri Mar 28, 2014 12:30 pm
Users browsing this forum: No registered users and 107 guests
