What's these called?
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=51835
Author:  poke_chop666 [ Thu Mar 27, 2014 5:10 pm ]
Post subject:  What's these called?
Where can I get these and what are they called?
Author:  marshmadnes08 [ Thu Mar 27, 2014 5:12 pm ]
Post subject:  Re: What's these called?
Bimini hardware. http://www.duckworksbbs.com/hardware/bimini/index.htm
Sent from my SM-N900V using Tapatalk
You building a boat blind?
Author:  barnes_53 [ Thu Mar 27, 2014 5:13 pm ]
Bimini top cap attached to a bimini top slide
If you are building a boat blind here ya go...enjoy. It is a link to my parts list I put together to build my blind using bimini hardware.
Author:  poke_chop666 [ Thu Mar 27, 2014 5:17 pm ]
Yea
Author:  poke_chop666 [ Thu Mar 27, 2014 5:18 pm ]
Wouldn't have it at lpwes?
Author:  jldsc [ Thu Mar 27, 2014 5:38 pm ]
I got all mine off of amazon...a West Marine may have it if you have one local.
Sent from an Apple Tree..
Author:  lizard55033 [ Thu Mar 27, 2014 5:42 pm ]
neat info
Author:  marshmadnes08 [ Thu Mar 27, 2014 5:45 pm ]
I made mine last year.
Author:  marshmadnes08 [ Thu Mar 27, 2014 5:46 pm ]
Author:  fowllife08 [ Thu Mar 27, 2014 6:09 pm ]
West marine is where i got mine. Amd the picture of marsh madness' frame is why ur gonna need a welding machin and a stick of 1\2
Author:  marshmadnes08 [ Thu Mar 27, 2014 6:22 pm ]
Def need to weld. The coupling didn't hold up. I welded mine up.
Author:  poke_chop666 [ Fri Mar 28, 2014 3:55 am ]
Caleb u ever measured ur blind to see if it will fit? I may just buy yours
Author:  fowllife08 [ Fri Mar 28, 2014 4:28 am ]
Author:  poke_chop666 [ Fri Mar 28, 2014 4:54 am ]
Ordered the stencils last night. It will be painted but gonna put a blind too.
Author:  fowllife08 [ Fri Mar 28, 2014 5:11 am ]
Author:  rob_E [ Fri Mar 28, 2014 7:42 am ]
Poke Chop you can get the Bimini Hardware at most boat Dealers that sell parts I got mine at Thomas Marine in Gonzales, LA Everything I needed was in stock.
Author:  MDMarsh [ Fri Mar 28, 2014 8:43 am ]
Your gonna have to bore the hardware out a little to fit the 3/4" conduit. A dremel with a small cutting bit will work just fine. Just a few passes around the inside. Also like these guys are saying get some 1/2" and cut it into 3' sections. insert 18" into the end of the 3/4" and tack it in place. Then slide a second stick of 3/4" and weld all the way around. 100Xs better than couplings.
Author:  poke_chop666 [ Fri Mar 28, 2014 12:29 pm ]
Terrain phantom- ground shadow.
Author:  poke_chop666 [ Fri Mar 28, 2014 12:30 pm ]
