gas tank install http://mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=55519 |
Author: | mike9b9 [ Thu Aug 07, 2014 2:38 pm ] |
Post subject: | gas tank install |
I have attached a pick of my boat as it was being built. This pic shows the frame work with out the welded in floor . I want to place the fuel tank just past the longitudinal braces in the bow of the boat. Is it wise to drill through the lateral brace ( the one the longitudinal braces are welded to) to run the fuel line through? |
Author: | msm8281 [ Thu Aug 07, 2014 2:53 pm ] |
Post subject: | Re: gas tank install |
It shouldn't be a problem, but I wouldn't run a hose. I would use stainless tubing and be done with it. You will catch hell changing out the hose. Well unless you have gutters. |
Author: | dixieducker [ Thu Aug 07, 2014 3:21 pm ] |
It wouldnt hurt anything, but would be hard to get to if something happened to the line. I would run half pipe down the side to run your hoses though. |
Author: | mike9b9 [ Fri Aug 08, 2014 6:42 pm ] |
[youtube][/youtube]I like the stainless idea, do you use compression fittings to transition to the regular gas line? |
Author: | msm8281 [ Fri Aug 08, 2014 10:07 pm ] |
Author: | JLACOUR [ Fri Aug 08, 2014 10:17 pm ] |
What's sweglok?? ![]() |
Author: | msm8281 [ Fri Aug 08, 2014 10:23 pm ] |
Author: | JLACOUR [ Fri Aug 08, 2014 10:33 pm ] |
