It is currently Tue Jun 24, 2025 7:05 pm
Reply to topic  [ 8 posts ]
 gas tank install
Post gas tank install
I have attached a pick of my boat as it was being built. This pic shows the frame work with out the welded in floor . I want to place the fuel tank just past the longitudinal braces in the bow of the boat. Is it wise to drill through the lateral brace ( the one the longitudinal braces are welded to) to run the fuel line through?
Thu Aug 07, 2014 2:38 pm
Post Re: gas tank install
It shouldn't be a problem, but I wouldn't run a hose. I would use stainless tubing and be done with it. You will catch hell changing out the hose. Well unless you have gutters.
Thu Aug 07, 2014 2:53 pm
It wouldnt hurt anything, but would be hard to get to if something happened to the line. I would run half pipe down the side to run your hoses though.
1748 Cottonmouth Hybrid Custom with a 2015 35GTR
7 yr old Boykin Spaniel
One Badazz wife that that hunts like a champ
ROLL TIDE!!
Thu Aug 07, 2014 3:21 pm
[youtube][/youtube]I like the stainless idea, do you use compression fittings to transition to the regular gas line?
Fri Aug 08, 2014 6:42 pm
Fri Aug 08, 2014 10:07 pm
What's sweglok??
37 PD EFI FPR 18x48 Tiller
SOLD -- 27 PD FPR 16x36 Skiff
Fri Aug 08, 2014 10:17 pm
Fri Aug 08, 2014 10:23 pm
Fri Aug 08, 2014 10:33 pm
Users browsing this forum: Google [Bot] and 136 guests
cron
