| DIY Styx River Nat Gear camo http://mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=55572 |
| Author: | duckhunter888 [ Sat Aug 09, 2014 6:43 pm ] |
| Post subject: | DIY Styx River Nat Gear camo |
| Author: | JLACOUR [ Sat Aug 09, 2014 6:47 pm ] |
| Post subject: | Re: DIY Styx River Nat Gear camo |
Fine job!! |
| Author: | jc [ Sat Aug 09, 2014 6:59 pm ] |
Damn fine job! How long did it take? |
| Author: | duckhunter888 [ Sat Aug 09, 2014 7:05 pm ] |
| Author: | jc [ Sat Aug 09, 2014 7:20 pm ] |
I can't believe how good you got it around the floor braces and the half pipes down the sides. And you camoed everything. It really shows that you took a lot of time with it, looks great. How did you get the stencils to bend around everything so well? |
| Author: | duckhunter888 [ Sat Aug 09, 2014 7:28 pm ] |
Thanks for the compliments. I turned the hull upside down to do the outside and the stencils lay flatter, using a coat hanger around the v crimp helped as well. In the end I just cut up a stencil and used in the tight areas and bracing. Patience is key, and keeping the stencils clean also leads to better results. |
| Author: | beau21382 [ Sat Aug 09, 2014 8:24 pm ] |
What brand/color is your base coat? |
| Author: | duckhunter888 [ Sat Aug 09, 2014 8:36 pm ] |
| Author: | beau21382 [ Sun Aug 10, 2014 4:30 am ] |
Thanks. It came out really good. |
| Author: | Full Throttle [ Sun Aug 10, 2014 9:55 am ] |
Boat looks awesome. Ive always liked the lines on brothers hulls. Post up a report when it's finished. |
| Author: | duckhunter888 [ Sun Aug 10, 2014 10:16 am ] |
Thanks FT, have a GTR on order and still collecting info on the transom angle issue. This one is at 15 degrees and not 20 degrees like GT specs on their boats. From what I hear there are viable options - per Brother he never has had a hull he has built not run well with a GTR on this transom angle (I absolutely believe this), shimming to get a deeper bite if I need to dig out. I expect it to run and perform but want to ensure it will be the best setup on whether I shim or not. I just want to get back on the water. |
| Author: | KJH [ Mon Aug 11, 2014 3:13 pm ] |
Love it. The boat and paint look great. |
| Author: | Frog [ Mon Aug 11, 2014 3:43 pm ] |
Very Nice!!! |
| Author: | Tcounty [ Mon Aug 11, 2014 9:08 pm ] |
Nice. I sprayed Natural base on mine, but never finished |
| Author: | brasso [ Mon Aug 11, 2014 9:28 pm ] |
That boat is beautiful |
| Author: | duckhunter888 [ Mon Aug 11, 2014 9:37 pm ] |
I appreciate the comments guys. |
