bpgast
 access hatches
Tried the search couldn't fine what I was looking for.
Anyone add a access hatch to their bench seat for more storage? What brand, type, did you like it?
_________________ MB 35hp LT/1754 Grizzly
| Thu Aug 21, 2014 6:34 pm |
nasty
 Re: access hatches
What are you type looking for?
| Thu Aug 21, 2014 7:50 pm |
bpgast
 Re: access hatches
Cut and drop in kind. Just looking for ideas.
| Thu Aug 21, 2014 7:59 pm |
jldsc
 Re: access hatches
man I had a pic of one I just put in one of my boats...if I can find the name brand ill post it up for ya....I got the dealership I bought my bay boat from to send me one...west marine has some you can look at and TH Marine has some also...check amazon for marine hatch's
| Thu Aug 21, 2014 8:17 pm |
msudawg10
Joined: Fri Feb 10, 2012 10:04 am Posts: 70 Location: Jafrica, MS
 Re: access hatches
I got one off eBay I don't remember the exact dimensions but it's around 10x14 I think I'll try adding a pictureImageUploadedByTapatalk1408737606.807073.jpgImageUploadedByTapatalk1408737630.742186.jpgImageUploadedByTapatalk1408737649.373730.jpg
| Fri Aug 22, 2014 2:00 pm |
caddobrook
 Re: access hatches
do a search on ebay. search for boat hatch. a ton come up.
believe the ones I have used in past are the tempress ones
| Fri Aug 22, 2014 4:28 pm |
btmannin
Joined: Tue Jan 15, 2013 5:25 pm Posts: 1723 Location: Oxford/Jackson ms
 Re: access hatches
I put a tempress hatch in the middle seat of all my little Jon boats. They do the job and are worth their weight in gold for stowing clutter type chit
_________________ 1436 tin can shoved by a 16 GDLT 16.5x48 running like hell from a built 40 merc
| Fri Aug 22, 2014 4:35 pm |
bpgast
 Re: access hatches
Any one see any aluminum hatches anywhere?
How do the plastic ones hold up if standing on them?
| Fri Aug 22, 2014 4:54 pm |
ajverret
Joined: Sun Sep 29, 2013 5:33 pm Posts: 645 Location: New Iberia, La
 Re: access hatches
Cabelas has the aluminum ones
_________________ 1848 Uncle J and 37 EFI GTR
| Fri Aug 22, 2014 5:04 pm |
ajverret
 Re: access hatches
| Fri Aug 22, 2014 5:07 pm |
btmannin
 Re: access hatches
| Fri Aug 22, 2014 5:24 pm |
jldsc
 Re: access hatches
my podna is 265lbs and walks on mine
| Fri Aug 22, 2014 5:58 pm |
bpgast
 Re: access hatches
I like the Cabela's one, looks like it would be more flush. Thanks everyone for the input.
| Fri Aug 22, 2014 7:45 pm |
Morning Woodie
 Re: access hatches
Tempress. Mine worked fine standing on it but it was a relatively smaller hatch. Was water tight as well.
| Sat Aug 23, 2014 7:00 am |
Honky Kong
Joined: Fri Feb 22, 2013 3:41 pm Posts: 227 Location: Mankato, MN
 Re: access hatches
The hatches from Cabela's are tough. I put the large one in the small front deck on my boat. It get's walked on all the time and is built for it. They are spendy but worth every penny in my opinion. I'll be adding a couple of the medium sized ones as well. I searched for a long time online and they seem to be the toughest ones available.
_________________ Backwater Swomp 23 / Lowe L1448M
| Sun Aug 24, 2014 12:12 pm |
bpgast
 Re: access hatches
Went with the Cabelas one. Cut the hole and started taking foam out of bench, what a pain in the *ss! Have another question, does the foam give needed support to the bench itself? As I started taking foam out, seemed that the bench gave a little in the middle. Can I take all the foam out?
Anyone done this to a Tracker Grizzly before?
| Tue Sep 02, 2014 12:38 pm |
GDSArgo
Joined: Tue Dec 03, 2013 12:39 pm Posts: 341 Location: Houston Delaware
 Re: access hatches
Pulled all the foam out of my old boat you'll be ok it'll stiffen up when you put the hatch in, but if you want leave some around the edges as padding so stuff doesn't beat around.
Sent from the company's iPad while at work
_________________ Dont criticize a farmer with your mouth full
| Tue Sep 02, 2014 4:42 pm |
msudawg10
 Re: access hatches
^ and have fun pulling that foam out. It's miserable
| Wed Sep 03, 2014 7:28 am |
GDSArgo
 Re: access hatches
Piece of flat bar heated up acts like a hot knife thru butter makes it easy
| Wed Sep 03, 2014 8:01 am |
bpgast
 Re: access hatches
Thanks guys. Will try the hot flat bar when my back decides its not still mad at me.
| Thu Sep 04, 2014 4:12 pm |
ajverret
 Re: access hatches
A pressure washer works with a turbo tip but it makes a mess
| Thu Sep 04, 2014 5:18 pm |
bpgast
 Re: access hatches
Update. Got both hatches in and took almost all the foam out. Left the foam right under the seat mount for support, just in case. If it gets waterlogged, will pull it too. Removing the foam was fun! Not! Everything did firm up once hatches were installed.
Added a lot of extra storage. Thanks again everyone for your help and advise.
| Mon Sep 15, 2014 5:37 pm |
GDSArgo
 Re: access hatches
That turned out really good. Enjoy the storage
| Mon Sep 15, 2014 5:56 pm |
North LA Hunter
Joined: Mon Aug 02, 2010 8:39 pm Posts: 6976 Location: West Monroe, LA
 Re: access hatches
Looks like they were supposed to go there!
Good job!
Sent from my beeper
| Mon Sep 15, 2014 7:16 pm |
bpgast
 Re: access hatches
Thanks, very happy with them.
| Tue Sep 16, 2014 12:04 pm |
