It is currently Sat Dec 13, 2025 2:55 pm
[ 8 posts ] |
benelli08
 Transom height
I usto have a gator tail boat 18x 48 and it ran we'll I have a 3/16 18x46 and it don't really run like it should it runs flat the whole bottom of the boat makes contact. With water where as my gator tail boat would run with bout 5 ft in the water .We'll come to find out my transom is 19.5 on my new boat . Where as they should be 21 like on the gator tail boats. Gator tail boats have that double angled transom with that 45 at the bottom and my new boat is a old style with trim tabs should they both be 21 or will they be different with the different transom styles
_________________ 2010 gtr cdi with a stage 2 pushing a 18x46 home made HEAVY DUTY boat
| Sat Jan 31, 2015 8:00 am |
WhoDat88
Joined: Thu May 23, 2013 4:24 pm Posts: 2912 Location: Thibodaux, La
 Re: Transom height
_________________ 1850 Predator Series Stick Steer Option 40HP Gatortail
| Sat Jan 31, 2015 9:21 am |
benelli08
 Re: Transom height
Straight up with a right angle that's how I was told
| Sun Feb 01, 2015 8:57 am |
cupnglide
 Re: Transom height
Here's a reference for those that don't have a link. http://www.seamount-mattson.com/trandiag.htm
| Sun Feb 01, 2015 11:21 am |
debo
Joined: Sun Jan 05, 2014 7:05 pm Posts: 143 Location: Southeast, LA
 Re: Transom height
Mines also at 19.5, would it perform better at 21"? Would we see a performance gain in speed and holeshot? Thinking about getting mine welded to 21" just curious if i will see any gain by doing it.
| Mon Feb 02, 2015 1:29 am |
benelli08
 Re: Transom height
I ran mine this weekend at 21 inches just blocked it up dint see that much of a diffrene at all may just split the diffrence and call it good
| Mon Feb 02, 2015 2:16 pm |
Roostertail3
Joined: Sun May 22, 2016 10:32 am Posts: 334 Location: Middle ga
 Re: Transom height
I know this is an old post but I just put a GTR in my prodigy, my transom is 19.5” and the dealer mounted the motor with a 1” gap between the transom and the motor mount. I don’t like they way they did it but it was done when I picked it up. They talked to Bubba at GT and he told them to mount it like that and to run it in the top pin. The motor vibrates like a mofo, not sure if it’s a prop (stock 2 blade) or because the motor is not sitting all the way on the transom. Did you end up keeping it at 21 or do you think 19.5 would work fine.
| Tue Jan 08, 2019 11:35 am |
Wchauvin
 Re: Transom height
Good to know Bubba at gatortail (a salesman and not a performance or shop guy) is telling boat companies where to mount motors.....smh. It should be mounted flush to the transom and should be 21 inches. If your transom is not 21, adjust he Lin and run it each setting and see where your performance is at with each setting
| Tue Jan 08, 2019 5:35 pm |
[ 8 posts ] |
