It is currently Mon Dec 22, 2025 11:03 am
Reply to topic  [ 16 posts ]
 LED Light Strips
Post LED Light Strips
Ordered a couple of strips to cut up and put in my storage compartments, but am having some troubles.
I know where to cut them and how to cut them, but where do I find the connectors to make the strips I cut off work? I'm running a fair amount of salt, so I need something that will stand up to the corrosion or at least the water hitting it.
I have seen the youtube videos of people with snap on connectors and I'm assuming you can solder it also (which I SUCK at). Anyone have any helpful ideas or suggestions?
1844 GD with 35HP GDSD
Tue Apr 14, 2015 11:05 am
Post Re: LED Light Strips
2014 PD 18x54 SBX w/ 36 EFI PD E5
Tue Apr 14, 2015 11:22 am
what's a good sealant?
Tue Apr 14, 2015 11:57 am
Adhesive lined heat shrink.
Tue Apr 14, 2015 1:12 pm
^^that^^^
Tue Apr 14, 2015 1:22 pm
clear I'm assuming :lol:
Tue Apr 14, 2015 1:52 pm
Not sure what you mean.
Tue Apr 14, 2015 2:21 pm
Heat shrink wire connections, but i also seal them with liquid electric tape in case shrink wrap leaks. Hidden corrosion connections can be hard to find. I have also used clear silicon on connections.
After all is sealed and ready to go, I still spray down with corrosionX about twice per year if I'm going around salt water. Aerosol corrosionX is easier then pump spray.
Tue Apr 14, 2015 4:04 pm
I use adhesive lined heat shrink for anything in the boat. It seals up the connection perfectly. Little more expensive, but really not that bad.
Tue Apr 14, 2015 4:12 pm
does anyone know if I can connect one strand to another or do each of them need to be individually run back to the switch?
Tue Apr 14, 2015 6:47 pm
There is a limit to the number of leds lights per strand, but no issues for a boat. For most brands....All the lights are wired in parallel, so you can cut and connect anywhere along the strand.
Tue Apr 14, 2015 8:30 pm
over 40' is when you need to consider how your supplying power
1650 ribbed abused by a Gt-35 and push pole reverse
Thu Apr 16, 2015 9:19 am
They make "marine heat shrink" that has a sealant in it that's heat activated. It turns into a gel and then hardens after it cools inside the sleeve.
http://www.amazon.com/Ancor-Marine-Elec ... B000QCPKE8
Thu Apr 16, 2015 6:21 pm
How precise does the diameter have to be with the heat shrink? 1/2" to big or can i melt it on?
Thu Apr 16, 2015 8:24 pm
Thu Apr 16, 2015 8:32 pm
Fri Apr 17, 2015 10:54 am
