It is currently Wed Mar 18, 2026 2:53 am
Reply to topic  [ 12 posts ]
 Split Seat
Post Split Seat
Fixin to make a split seat out the huge bench o my grizzly. and take all dat foam out! any one has done this? gimme some tips
Tue Apr 28, 2015 6:33 pm
Post Re: Split Seat
I cut the middle our of my 2 benches and left small pods on each side which I put seat mounts in. The pods also house my speakers, led lights, 12 volt outlets and switch panel. I ran lengths of angle aluminum from side to side to try to maintain some of the integrity and support that the seats gave my hull. Did away with all the foam. Hopefully I never need it.
Backwater Swomp 23 / Lowe L1448M
Tue Apr 28, 2015 10:25 pm
Post Re: Split Seat
viewtopic.php?f=4&t=61498
This guy did.
Wed Apr 29, 2015 12:27 pm
Post Re: Split Seat
Yea i was thinking about supporting all the outer edge of each side with some angle aluminum and using it to house my battery and make a switch panel under my seat.
Wed Apr 29, 2015 7:05 pm
Post Re: Split Seat
I just posted pics in the speakers thread a few below this thread if you haven't seen em already check em out. Sounds like what I did is what you are looking to do.
Wed Apr 29, 2015 10:22 pm
Post Re: Split Seat
best thing I ever did to my grizzly
Thu Apr 30, 2015 12:44 pm
Post Re: Split Seat
built a grab bar too, second best think I did to it
Thu Apr 30, 2015 12:50 pm
Post Re: Split Seat
You did the seat yourself?
Fri May 01, 2015 5:29 pm
Post Re: Split Seat
yes, it was very easy. Layed it out with a sharpie marker. drilled a couple start holes and used a jig saw. Made the bottom and end caps but I don't have access to alum welder so i paid a shop to do that.
I'll post another picture today of the other side....thats where my switch panel and rev limiter box is mounted
Sat May 02, 2015 4:44 am
Post Re: Split Seat
Ima try to do it to where i can use the piece i cut out as an end cap
Sun May 03, 2015 5:25 pm
Post Re: Split Seat
here is the other side, I mounted my rev limiter in the watertight box and have all my wiring in there
Mon May 04, 2015 5:02 am
Post Re: Split Seat
Wed Jun 12, 2019 8:05 am
