| Split Seat http://mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=61530 |
| Author: | BERNIE255 [ Tue Apr 28, 2015 6:33 pm ] |
| Post subject: | Split Seat |
Fixin to make a split seat out the huge bench o my grizzly. and take all dat foam out! any one has done this? gimme some tips |
| Author: | Honky Kong [ Tue Apr 28, 2015 10:25 pm ] |
| Post subject: | Re: Split Seat |
I cut the middle our of my 2 benches and left small pods on each side which I put seat mounts in. The pods also house my speakers, led lights, 12 volt outlets and switch panel. I ran lengths of angle aluminum from side to side to try to maintain some of the integrity and support that the seats gave my hull. Did away with all the foam. Hopefully I never need it. |
| Author: | b.latiolais [ Wed Apr 29, 2015 12:27 pm ] |
viewtopic.php?f=4&t=61498 This guy did. |
| Author: | BERNIE255 [ Wed Apr 29, 2015 7:05 pm ] |
Yea i was thinking about supporting all the outer edge of each side with some angle aluminum and using it to house my battery and make a switch panel under my seat. Sent from my iPhone using Tapatalk |
| Author: | Honky Kong [ Wed Apr 29, 2015 10:22 pm ] |
I just posted pics in the speakers thread a few below this thread if you haven't seen em already check em out. Sounds like what I did is what you are looking to do. |
| Author: | woodsman1977 [ Thu Apr 30, 2015 12:44 pm ] |
best thing I ever did to my grizzly |
| Author: | woodsman1977 [ Thu Apr 30, 2015 12:50 pm ] |
built a grab bar too, second best think I did to it |
| Author: | BERNIE255 [ Fri May 01, 2015 5:29 pm ] |
You did the seat yourself? Sent from my iPhone using Tapatalk |
| Author: | woodsman1977 [ Sat May 02, 2015 4:44 am ] |
yes, it was very easy. Layed it out with a sharpie marker. drilled a couple start holes and used a jig saw. Made the bottom and end caps but I don't have access to alum welder so i paid a shop to do that. I'll post another picture today of the other side....thats where my switch panel and rev limiter box is mounted |
| Author: | BERNIE255 [ Sun May 03, 2015 5:25 pm ] |
Ima try to do it to where i can use the piece i cut out as an end cap Sent from my iPhone using Tapatalk |
| Author: | woodsman1977 [ Mon May 04, 2015 5:02 am ] |
here is the other side, I mounted my rev limiter in the watertight box and have all my wiring in there |
| Author: | ccraig27 [ Wed Jun 12, 2019 8:05 am ] |
