| Removable front deck extension http://mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=63389 |
| Author: | lilderekj1127 [ Tue Aug 25, 2015 12:45 pm ] |
| Post subject: | Removable front deck extension |
I have a 1854 gator tail with 8" catwalks and was wondering if anyone has added a removable front deck extension. Trying to avoid having anything welded. Looking for any ideas or info of how I could do this. Looking to add maybe 3 feet. |
| Author: | msm8281 [ Tue Aug 25, 2015 12:50 pm ] |
| Post subject: | Re: Removable front deck extension |
Weld 1x1 angle on the front and sides facing down where you want the deck. Put it the height you want the deck. Build your deck with 2 legs and use the rest of the angle to strengthen the deck. Then just bolt to the angle. |
| Author: | lilderekj1127 [ Tue Aug 25, 2015 1:12 pm ] |
Thats how I first thought to do it but just trying to see if there's any way to do it without having to weld anything. |
| Author: | Howdy [ Tue Aug 25, 2015 2:39 pm ] |
Build it out of wood |
| Author: | flint87 [ Tue Aug 25, 2015 3:58 pm ] |
Build it out of fiberglass Sent from my iPhone using Tapatalk |
| Author: | lilderekj1127 [ Tue Aug 25, 2015 4:24 pm ] |
I was thinking of getting a piece of aluminum and bolting a frame of angle under it and then bolting that to my catwalks. Do you think that would be strong and sturdy enough. Also would add some sort of legs to support it. |
| Author: | North LA Hunter [ Tue Aug 25, 2015 8:02 pm ] |
Is there any reason why you don't want it welded it? Spud pole holes would work well in your catwalks that you could drop your deck in and pull out very simple. But if not bolting wouldn't be too bad. Sent from my beeper |
| Author: | LB200 [ Tue Aug 25, 2015 8:30 pm ] |
I am sure you could bolt on some type of tubing to catch it but welding is going to be stronger and look a lot better in the long run. Mine was done at the factory but a similar system would work after the fact but it is all welded. |
| Author: | TPerkins [ Wed Aug 26, 2015 9:16 am ] |
Not my boat got it from the gt instagram, but seems like I nice set up. Not sure if the owner is on here. Sent from my SM-G900V using Tapatalk |
| Author: | 4Cody4 [ Thu Aug 27, 2015 6:19 am ] |
I have the same style extension. Couple bolts into rivnuts hold it in place. They are easy and sturdy. Sent from my iPhone using Tapatalk |
| Author: | steinb3rg [ Thu Aug 27, 2015 9:25 am ] |
Treated 1x2's and 1/2" treated plywood covered in hydroturf. Sits down around my rod boxes. Doesn't get bolted down or anything. Very easy to take in and out. |
| Author: | msm8281 [ Thu Aug 27, 2015 9:38 am ] |
Here is a back deck I had made. It just sets on top the gunnel on the sides and back of the boat. I have it bolted through the gunnel in a few places. It has the one leg that you see and a couple pieces of tubing welded to the bottom to stiffin it up. |
| Author: | lilderekj1127 [ Fri Aug 28, 2015 3:35 am ] |
Thanks for the info im going to try and build one similar. |
| Author: | bluesky2012 [ Thu Feb 27, 2020 9:51 pm ] |
I’m about to fab up a deck like TPerkins shows. Anyone have suggestions on the type and size of square tubing or other dimensions/schematics to show how they built theirs? Sent from my iPhone using Tapatalk Pro |
