luckyhat12
Joined: Thu Dec 08, 2011 5:50 pm Posts: 30 Location: DFW
![Post Post](./styles/acidtech_tiger/imageset/icon_topic_latest.gif) number of bunks on trailer
how many bunks do you guys have on your trailer? mine has two on the trailer for a 2054 with a .190 bottom. I don't have far to go to the lake when I'm at home but I have a few trips planned that are 12+ hour stretches on South Louisiana roads.
I'm trying to figure out if I should add more bunks to the trailer or not for those long, very bumpy rides.
I can replace the 2x4's with 2x6's no problem but I am also curious what the rest of you guys have and see if that is enough based on the general consensus
Thanks...
_________________ 2054 WC Custom CC pushed by a GTR
Thu Jul 27, 2017 3:00 pm |
![](./styles/acidtech_tiger/theme/images/spacer.gif) |
reharbert
Joined: Tue Mar 17, 2015 1:38 am Posts: 606 Location: Beaumont, Texas
![Post Post](./styles/acidtech_tiger/imageset/icon_topic_latest.gif) Re: number of bunks on trailer
Where do the runners fall out on your floor? Do they fall out under the runners?
Personally I have (4) 2x4s, laid down flat. 2 catch the outter edges, and two fall out under runners.
_________________ Uncle J - 17 x 48 w/GTR | Bayou Surface Drive heads | Voodoo exhaust | DIY Mikuni carb
Thu Jul 27, 2017 3:04 pm |
4Cody4
Joined: Thu Mar 31, 2011 11:21 am Posts: 2530 Location: Land of 10,000 Lakes
I have 4 bunks (2x6) laid flat that fall under the boat like described above.
_________________ "Two people in this world wear helmets, and that's dare devils and pussies." - Willie Braun
Thu Jul 27, 2017 3:36 pm |
Will C
4 2x6ers here
Thu Jul 27, 2017 4:56 pm |
CypressCritter
Joined: Tue Aug 26, 2014 10:36 am Posts: 822 Location: Jefferson TX
4 2x6's under a 54" bottom 3/16/.190, 2 seems like not enough.
_________________ SEAARK FX 2472 CC Merc 150HP 4Stroke(CypressCadillac) Uncle J Custom - 19x54 CC Skiff w/40XD GTR
Fri Jul 28, 2017 7:56 am |
North LA Hunter
Joined: Mon Aug 02, 2010 8:39 pm Posts: 6976 Location: West Monroe, LA
3 - 2x6 on my 54".
Fri Jul 28, 2017 9:21 am |
luckyhat12
photobucket has changed their image rules so I can't post a picture yet. I'll try google... It doesn't embed, but here is what they look like. https://photos.app.goo.gl/w7hsAXrgrKKqVf0B3I can't tell if they are under the runners or not without climbing in and measuring from the edge of the boat. It has enough room to slide around that it probably slips off part of them anyway. I'll measure this weekend when I'm not at work. Looks like I'll be upgrading the 2x4's to at least 2x6's and will be on the look out for new brackets to add more. The existing brackets are welded on but I know there are clamp on brackets as well. I may be able to weld tabs on later but that is still unknown at the moment. Thanks for the help guys... I appreciate it.
Fri Jul 28, 2017 11:20 am |
Frog
4
_________________ http://www.gatorglide.com/
gatorheads@comcast.net
Fri Jul 28, 2017 2:36 pm |
4Cody4
I'm considering just adding plywood over my bunks and adding a big sheet of poly.
Fri Jul 28, 2017 2:50 pm |
TonyGMcElroy
Joined: Tue Nov 15, 2011 3:27 pm Posts: 664 Location: Henderson, Tx
Fri Jul 28, 2017 9:12 pm |
petrel
Joined: Mon Jan 11, 2010 9:51 am Posts: 770 Location: NVA
4 - 2 X 6s laid flat
_________________ Phowler 2066 w/ E5 37 ProDrive w/ Illowa Marine Heads MoMarsh Fatboy/2 Honda
Sun Jul 30, 2017 1:58 pm |
Frog
Mon Jul 31, 2017 10:42 am |
BadBowtie
Joined: Wed Jan 14, 2009 5:04 pm Posts: 268 Location: Mt. Vernon, IN
4.
_________________ 1848 GTB, 36 PD w/ FPR
Tue Sep 12, 2017 2:42 pm |
