It is currently Sat Nov 07, 2026 10:12 pm
[ 7 posts ] |
Surface Drive-Flood or Spot Lights
Synergy15
I am looking for advice or opinions based on experience..
What type of light system works best on a surface drive boat. I am looking at a Rigid 10" spot/flood combo or two individual rigid spot lights. Does anyone have any experience with these or can recommend a better set up. I am going to make the light mount quickly removable.
Thanks ahead of time for the comments.
| Thu Sep 14, 2017 8:37 pm |
4Cody4
Joined: Thu Mar 31, 2011 11:21 am Posts: 2530 Location: Land of 10,000 Lakes
 Re: Surface Drive-Flood or Spot Lights
I got a 20" light. AR from Amazon and put it up on a pole for running the river.
Light bars can be had for so cheap now that it hardly hurts to experiment.
If you are going rigid it will be spendy, and lots of guys mount them on the front.
_________________ "Two people in this world wear helmets, and that's dare devils and pussies." - Willie Braun
| Thu Sep 14, 2017 9:00 pm |
Duckslayer5200
I have two "8 spots on the front and two floods on the rear. I like the spots in the front because they work better in the fog. The floods on the back work great for backing up to the ramp in the dark and setting decoys.
| Fri Sep 15, 2017 6:53 pm |
umahunter
Joined: Thu Sep 24, 2009 4:18 pm Posts: 83 Location: yuma AZ
I have big off road floodlight I put on a helmet with battery clips and a long cable that way i can clip it on my trolling moter batterys up front also if i need light up front i can point light wherever I need it I like it way better than any other lights I mounted on the boat I also use my helmet light on the trolling battery's when I'm on the deck useing the trolling motor bow fishing
| Sat Sep 23, 2017 2:33 am |
duckrunner99
Joined: Sat Oct 26, 2013 1:00 pm Posts: 340 Location: Wisconsin
Southern lite led boat light gen to is what I would get if I were you. I you are looking at rigid I’m gonna guess it’s in your price range. It’s small and compact and if you get the Wiring harness and riv nuts it’s easliy removable. Light has steel housing around it and is strong as hell. And it’s easily the brightest light I have ever seen to date
| Wed Oct 11, 2017 6:41 am |
duckrunner99
ronbow
Joined: Sat Aug 15, 2009 2:40 pm Posts: 137 Location: Wolf Bay,Alabama
Combo spot/flood by Cree are what i got and they work well.and they plug into a Trol mtr plug and come out of a reciever when not in use.trolling motorr plugs have 3 wires i used the extra for a switched hot from the switch panel works for me Says Ronbow
_________________ Gator Trax 16/50 ---HDR Black Death 4500 BPS SWAMP STAFF
| Wed Oct 11, 2017 9:33 am |
[ 7 posts ] |
