deaddrake
![Post Post](./styles/acidtech_tiger/imageset/icon_topic_latest.gif) DIY boat blind ideas?
How many of you guys have built your own blinds that break down. I've looked at a couple designs with the Bemini hardware but worry about it breaking in the cold.
Sat Sep 09, 2017 9:01 pm |
![](./styles/acidtech_tiger/theme/images/spacer.gif) |
boatguy
Joined: Mon Dec 05, 2016 11:59 am Posts: 219 Location: Panhandle of Florida
![Post Post](./styles/acidtech_tiger/imageset/icon_topic_latest.gif) Re: DIY boat blind ideas?
Do a search. I used 3/4 electrical conduit and the plans from a scissor blind a guy did on here. Used the Bimini connections 7/8" and had to bore them out a bit (no bid deal with a drill and sanding wheel) I just finished it last week. It works amazing. Only had to drill two connections for the stern section of the blind (Bimini mail connections on the port and stbd side of the boat... I used rivets) and that was the only place I needed to put holes. I used the frond seat mount for the bow section of the blind. Made a T bar and it just slides in the seat hole
_________________ Lead, Follow or Get The Hell Out Of The Way!!!! 1754 Gator Trax Hybrid, Hunt Deck ,with MB 4400 Black Death HDR, Duck Slaying, Mud Slingin Machine!!!
Sun Sep 10, 2017 5:55 am |
Exbellicus
_________________ 2016 Prodrive X 1848 37efi
Mon Sep 11, 2017 3:44 am |
umahunter
Joined: Thu Sep 24, 2009 4:18 pm Posts: 83 Location: yuma AZ
You can get metal Bimini hardware aswell if you look up my screen name on the duck hunters refuge forum I've built sever different blind styles on there
Wed Sep 13, 2017 1:05 am |
CypressCritter
Joined: Tue Aug 26, 2014 10:36 am Posts: 822 Location: Jefferson TX
If you make a true scissor type blind, no fittings required. I use 1/2 conduit with 3/4 pre-bend 90s, and couple of short 3/4 pieces to make it longer. (could only find 8 ft. 1/2 conduit) Holding it together with SS self tapping screws, youtube it! cheapest way, those Bimini fittings are close to $20 a piece.
_________________ SEAARK FX 2472 CC Merc 150HP 4Stroke(CypressCadillac) Uncle J Custom - 19x54 CC Skiff w/40XD GTR
Wed Sep 13, 2017 7:52 am |
KRS62
Here is mine that I made:
Sat Sep 16, 2017 9:11 am |
deaddrake
exbellicious that is exactly the kind I'm looking at building
Sat Sep 16, 2017 12:03 pm |
BERNIE255
Joined: Sun Jun 16, 2013 4:43 pm Posts: 1381 Location: Avoyelles Parish/ Marksville LA
Heres mine i made it out of 3/4 conduit based off one i saw on here. I used a piece of solid aluminum rod that fit snug inside the pipe to connect the elbows to my center pieces and bolted it together.
Sun Sep 17, 2017 3:40 am |
JBouge
I made something similar to this using conduit with a bender and a few fittings/bolts/nuts from the hardware store. Very simple and easy to put up with one person. One end is secured with a bolt and wingnut locking the two sides together and the other end has a trailer hitch lock pin to hold that side together.
Wed Oct 25, 2017 10:16 am |
Bamaboy2223
Go with 3/4 rigid conduit. It's stout
Thu Oct 26, 2017 8:18 am |
Pas Tout La
Joined: Tue Jul 30, 2013 2:32 pm Posts: 254 Location: Lafayette, La
I threw this together last season. My plan is to go with raffia grass on some netting with a cordura backing for a wind breaker. It could use some design tweaking, but I'm happy with it for $80 in bimini hardware and $20 in 3/4" EMT conduit.
Thu Oct 26, 2017 8:37 am |
KRS62
Here is a video of mine. https://youtu.be/tgKsIAcWNzgSent from my SM-T810 using Tapatalk
Sat Dec 16, 2017 9:16 pm |
BOATADDICT
Not sure what style of gunnel rails you have. I have the accessory type so this is what I did. I made 4 brackets out of bent aluminum plate anchored with carriage bolts that slide into the rail where I mounted my bimini hardware. It's a scissor type blind so I can pull 4 pins and take it off the boat in a few mins. I believe all of my bimini fittings are 1" inner diameter so I made the frame with 1" grey electrical conduit. Had to put some tubing inside the long sides to keep it from sagging in the middle with the weight of the fastgrass. Agree the the stainless bimini hardware is kinda pricey but it sure is convenient to put on and take off.
_________________ 22'x72" Boatright w/ 200 Yamaha SHO 14' Alumacraft w/ modded 6.5 Backwater
Sat Dec 16, 2017 10:23 pm |
Choot'em
Joined: Sun Nov 04, 2012 4:52 am Posts: 58 Location: Selmer,TN
I threw this together 2 years ago still holding up strong
Mon Dec 18, 2017 1:43 pm |
Ducknut
Joined: Wed Apr 15, 2009 5:38 pm Posts: 238 Location: MN
Best prices I found for SS bimini hardware was at marinepartdepot dot com
Thu Dec 21, 2017 6:21 am |
